I have committed the cardinal sin
Old 09-24-2009, 12:21 PM
wack61's Avatar
Default I have committed the cardinal sin
I started the XK8 earlier this week ,moved it 10 feet then switched it off without thinking, got in it this afternoon, it won't fire and stinks of petrol.
Looks like my saturday morning is spoken for then
This really is a design fault on these cars
Old 09-24-2009, 12:37 PM
Gus's Avatar
Gus
Gus is offline
Received 2,212 Likes on 1,702 Posts
If you have fuel and spark pull the plugs add a few drops of oil reinstall the plugs hold the accelerator to the floor and hope it starts.
Old 09-24-2009, 03:59 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
don't beat yourself up too bad wack, there are worse things you could forget, even temporarily.
Old 09-24-2009, 04:08 PM
Gus's Avatar
Gus
Gus is offline
I have been down that road 3 times so you are not the only one. You can read my episode on my page if that will make you feel better.
Old 09-24-2009, 04:49 PM
wack61's Avatar
I had a S Type with the same engine last year, at least I know what it is now , when the S type wouldn't start I was really scratching my head, might be a good opportunity to put some new plugs in
Old 09-24-2009, 05:16 PM
Robscountach's Avatar
What is this about ? Is there an issue with on/off engine running ?
Old 09-24-2009, 05:24 PM
Gus's Avatar
Gus
Gus is offline
Don’t know just yet but I am certain we will find out!
Old 09-24-2009, 05:26 PM
SeismicGuy's Avatar
Is this type of thing (starting the car briefly maybe to just move it and then turning it off) poison to just these cars or to all cars.
Doug
Old 09-24-2009, 06:35 PM
Spurlee's Avatar
What?!? I've done that a dozen times with my XK8 and thouahds with other cars without a problem. I think there's another issue at hand here...
Old 09-24-2009, 06:46 PM
brgjag's Avatar
huh, what is this being talked about????
Old 09-24-2009, 07:49 PM
Gus's Avatar
Gus
Gus is offline
Cylinder wash! And this is not related to all cars.
Old 09-24-2009, 07:52 PM
An XK8 being started for a few seconds, then cut off, but won't start again... seems like a recurring issue via the first few posts.
Old 09-25-2009, 06:11 AM
wack61's Avatar
It's quite a problem with the AJ V8 engine, when they're cold they inject a lot of fuel, if you start up and switch off within a few seconds then leave the car this fuel floods the engine,wets the plugs and washes the oil out of the barrels which lowers compression and makes the car hard to start.
I've had it 3 months now but this is the 1st time i've started it, drove it 10 feet then switched it off, I had a 4.0 Stype which did the same.
Anyway I got away with it this time, left it overnight and this morning it fired up OK ish, bit rough to start with but running fine now
Old 09-30-2009, 09:01 PM
tonycottrell's Avatar
I learn so much from you guys. So, I am doing the right think my always being **** retentive and waiting until the temperature gauge goes to 12:00 before turning off the engine, correct? I even leave it running in the driveway if I back it out to wash it.
Tony
97 XK8
05 XJ8L
Old 09-30-2009, 09:29 PM
Honestly, its smart to let you 'fast' idle drop anyway before moving the car. I also do, on any car, even if late.
JimC64
64
01-13-2016 11:43 AM
millertic
09-30-2015 08:11 PM
Col. Sandurz
09-28-2015 12:49 PM
thomash85715
04-06-2012 10:51 AM
Quick Reply: I have committed the cardinal sin
