I love my XK8 but it's so damn uncomfortable!
I've had my XK8 for a few months now and I love everything about it except the seat. I just can't get comfortable.
It seems that the middle bit of the seat base (the sort of horseshoe-shaped bit) is too recessed, which puts my weight on my hips, and the back seems to curve in a different way to the human body.
Am I alone in this, or is it common? Is there a solution?
I've tried every adjustment. I'm going to strip the seat down at the weekend just to make sure there isn't anything wrong under the covers.
The main problem for me is that the base seems an odd shape - rather than a reasonably flat seat with lateral support, it seems more like the sides and front are built up and one has to try and sit down into the horseshoe area.
If you're comfortable doing mechanical work this can be done, but to get at the seat foam bottom you'll have to remove the seat from the car then then the cover. That means cutting about two dozen hog rings, all of which you'll have to replace, and disconnecting several electrical harnesses.
As I said quite doable if you know what you're doing, and have tools to do it, but it's not as easy as it might seem.
Regards,
Regards,
Received 4,312 Likes
could be the cushion has compressed but when I had mine off a few weeks back replacing the leather, on the seat bottom, there is a piece of hard rubber with several rods stretching it across the seat frame - the cushion is supposed to rest evenly on this. On my driver's side seat, the rubber had split so it no longer provided support to the cushion. Trying to source a replacement now but will try to get a pic
Lightsaber (05-19-2016)
I'm a big bugger and find the seats in my 03 very comfortable, I too have sheep skins, always put them in my convertibles to keep the seats from being to hot, reduce wear on the leather and comfort. I found when I put them on my XK8 that it seemed to raise me out of the seat pocket a little, at first I did not like it but got use to it and am very satisfied. They are not cheap, from CA Custom Car Covers I paid $550, they are custom fit and very well made.
I had a similar issue with seating low in to the center of the seat, traced a torn cushion support. This rubber membrane secured by rods with hook-ends. Dealer was happy to tell me this was only available when purchasing the entire seat frame assembly (3K USD). I fashioned a new cushion support from several (4 or 5, I don't remember) 2" webbing straps, looping the straps around the tubular seat frame and securing them to themselves with rivets and wide washers to keep the rivets from pulling through the webbing under the stress of the driver.
Worked very well, sat higher and the bolsters felt like bolsters again, not the sides of a bucket.
Another trick I had to employ for seating comfort, was to add washers at the rear seat frame mounting points, to tilt the seat slightly forward. Fits me better now.
It all starts with getting the thing out, and looking at what needs to be addressed.
All the best,
Jerry
All the best,
Jerry
Jon89 (05-19-2016)
Bladerunner and Steve, please keep us posted. I have a 1998 too and have been looking at the seat bottom's compression for a while now. I always figured it was a worn foam rubber pad under the leather, sounds like it is the supports Steve and Jerry mentioned.
I'd like to restore this someday and look forward to hearing about your progress. Thanks, John
