I-Pod Install
I would like to install an I-Pod in my 99 xk8 and would like a little input. I would like it to look clean and custom, no wires hanging out. What do you have and how did you connect it and where? I thought I saw a post that lead me to believe it was installed in the trunk at the CD player and the I-Pod was at the radio console. Was I dreaming?
I did an iPod install but I had to use the cassette player for the audio input. Here is the link, which is buried in somebody else's thread.
https://www.jaguarforums.com/forum/s...270#post121270
I use a cassette adapter with surprisingly good results. Tried a couple of them and ended up using Monster's - it definitely had the best sound. Plus its black with a black cable so with my interior (black) its pretty unobtrusive when I am using it.
Pro's: Sound quality much better than the FM transmitter units. When I am not using it, it all gets put away in the center box. It works with any MP3 or iPod. Inexpensive ($20 or so from Amazon)
Cons: Still not totally built in.
<a href="http://s171.photobucket.com/albums/u...urrent=161.jpg" target="_blank"><img src="http://i171.photobucket.com/albums/u...ttyjag/161.jpg" border="0" alt="Photobucket"></a>
If you wire in your Ipod properly you can even watch the videos.
Are those pic's of your car? I would like to hear about the engine mods.
Sweet ride
I connected my iPod to the CD player on my 2003 XKR. I ran the wires up into the console where the iPod sits out of sight. I have a switch so that I can switch between the CD player and the iPod. The only downside is that the CD player runs when the iPod is playing. You can remove the magazine and the iPod will still play. This approach allows the iPod to charge and the steeing wheel controls still adjust the volume. The direct connection of the audio to the Alpine provides the best sound quality, much better than the cassette adapters and FM modulators.
AJ
AJ
I took the plunge and purchased and installed an interface for my I-Pod and it works great and at the present time no noise with the engine running. this is the item I purchased http://www.discountcarstereo.com/detail.aspx?ID=1323 Thanks for all your input. Info on my page.
@stevepaa
I did some investigating after I tried and failed with the AUX switcher in my XJ. (I had tried it with the head unit set to CD and it didn't work. I then gave up)
I'm now 99% sure that it WOULD work if you connect it behind the head unit and then set the head unit to radio (not CD).... I think then you would hear the signal from the AUX switcher.
I'm also pretty sure it would work if you connected it between the CDchanger and the amp...... the problem with this is the connectors aren't correct (male/female) so you have to buy multiple cables and start hacking them.
If you still have the switcher and were willing to try an experiment, I'd like to see if it works behind the head unit with the head unit set to radio.
If you want to get the connection direct without a modulator or transmitter you can try the method we've been perfecting in the XJ forums here.....
https://www.jaguarforums.com/forum/s...ad.php?t=11943
AJ
AJ
philwarner
43
09-10-2023 11:30 AM
aholbro1
08-05-2021 05:02 AM
