I smell gasoline....big time
Hey guys - I have a 99 XK8 Conv and each morning when I start it up, there is a very strong gas smell. Anything special to look for? There are no visible exterior leaks or anything, but it is very pronounced. Calms down after a minute or two, and then is ok in stop and start daily routine, but very bad in the morning. Thanks for your input.
There is a charcoal filter in right hand front road wheel well, very possible a pipe has become dislodged. The filter sits between the door and the wheel behind the inner wheel arch panel.
Remove the wheel, I beleive there are about 9 fastenings of various types
, then you can remove the wheel liner and have a good look, shouldn't take you no longer than half an hour.
![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
Thanks - I will check that. I will say that at least some of the gas smell is coming from the exhaust on a cold startup. It smells up the entire area around the car, so I don't think I'll be able to locate it near a specific wheel.
I do have two "rich" CEL codes from time to time...they are not on now, but have been in the past. Not sure it the two relate, but worth mentioning.
Received 2,191 Likes
Thank you for the info - I will check on the recall item first, and my mechanic friend will help me in following the instructions that you all provided. As for CE codes, here is what I've had in the recent past (on/off):
PO172 and P1637 and the car goes into "performance restricted" mode for a short period, then will be normal again later in the day. I did replace the MAF and bought new plugs to install as well, yet to install the plugs though.
Wolfy
05-28-2024 08:06 AM
