Identifying Door Mirror
Hi
I wonder if anyone can help. I need a new LH Door mirror glass only. The current one has 3 x Lugs with 3 x Cables attached but all the mirrors I can find such as Part No HNA3074AA only seem to have 2 x lugs
What are the 3 x lugs I have for and could I use the version with only 2 x Lugs
Thanks for your advice
Paul
Paul
Hi Graham
Seems you are correct. On research last night, the 3 Lug version is the electrochromic mirror glass type. Unfortunately these are out of stock with all the suppliers I've looked at. I think I will try and install the standard version for now and wait for stock to become available as reversing and viewing what's behind me with a half brown cloudy mirror is not good
Have a good weekend
Have a good weekend
GGG (09-11-2021)
Paul,
I see it's a staggering 194 UKP from JLR but I also couldn't find any of the usual aftermarket suppliers with stock.
This could be a temporary solution for you:
https://www.cardoormirrors.com/custo...ng-mirror.aspx
Provided the edge is properly rounded and polished like the OE mirror, it could even be a permanent alternative.
Hi
Paul
Paul
androulakis
05-13-2010 07:16 AM
