Idler/tensioner Pulley Part #'s??
Well I am in the process of ripping apart the engine in my 2001 xkr and my one idler pulley was a bit suspect, definitely binding. I see that there appear to be two idler pulleys part #GATES 38028
I figured while I am at it I want to replace all of them. Changing bearings isn't in the job description as sourcing them on a Sunday may not happen. But I can find pulleys for sure. The above pulleys are available and its my understanding that's for the two stationary idler pulleys. What part numbers for the other ones? Much Appreciated!!! I don't want to have to do this again anytime soon
There is only one idler pulley on the engine. The other one is called a belt tensioner. Attached is an outline of the arrangement. Pc 7 is the idler and 8 is the tensioner.
You will probably won't be able to find an aftermarket tensioner. Most likely OEM or wrecking yard.
the part numbers are based on VIN number.
. Idler pulley
( to VIN 042775) NCA2221AA 1
(A00083 to A30644) AJ82266 1
(from VIN A30645) C2C37064 1
Drive belt tensioner
(Up to VIN 042775) NCA7739AC 1
(A00083 to A30644) NCA7739AD 1
( to VIN A39972) C2S11662 1
(from A39973 to A42347) AJ88003 1
(from A42348) C2S36146 1
. Idler pulley
WTT[LowerAtlantic]: Supercharger pulley tool?
flyc2c
03-05-2016 10:45 AM
