IDS SDD
Old 12-20-2022, 03:17 AM
Edmond124's Avatar
Originally Posted by slugger
ok, so I have a Cable(clone mongoose), have tried supplied SDD 160.4, that didn't work, also tried via VM, v125, 130, did not work either, so...is there a place where one can find installation files for say v130 or 125?
Cheers!
Bonjour, je suis nouveau j'ai besoin d aide j ai installé Sdd jlr mongoosse , je n ai pas d identifiant ni de code est il possible de m aider avec un code et identifiant. Merci
Old 10-03-2023, 10:23 AM
tlindi's Avatar
Default [SOLVED] SDD unable to start IDS - only splash image and then nothing
Originally Posted by baxtor
SDD is supposed to revert to legacy IDS on cars it detects as too old for SDD but in my experience getting legacy IDS to launch is a problem.
I have had more luck with standalone IDS on my 2000 MY.
You will require Rotunda VCM, not mongoose.
I found out how SDD125 and SDD131 can launch legacy IDS with a simple trick:
1) Backup c:\Program Files\JLR\IDS\runtime\tabman.exe (eg rename it to tabman.exe.org).
2) Find IDS118.5 tabman.exe (example from here: https://archive.org/download/JLR_SDD...0SDD131.03.zip ) and
3) Place tabman.exe to c:\Program Files\JLR\IDS\runtime\tabman.exe
Now your SDD can launch Legacy IDS - Vóila!
Br, tlindi
Old 10-03-2023, 11:50 PM
baxtor's Avatar
Received 1,165 Likes on 754 Posts
Br, tlindi
That is more or less how l run my IDS125, it was more so the later versions I found unhelpful. Even through the tabman option some simply froze or crashed.
Old 10-22-2023, 05:36 PM
xalty's Avatar
Received 1,061 Likes on 852 Posts
Br, tlindi
130 and up tabman vin select is locked with a seed
nebelfuerst
General Tech Help
06-24-2024 10:24 AM
joeleerj
22
10-05-2023 01:18 PM
Box
10-05-2023 07:51 AM
sayitaintso
01-29-2018 07:04 PM
barnter
General Tech Help
04-05-2016 01:00 PM
Quick Reply: IDS SDD
