Ignition coils
A quick search of an auto parts site indicates that the Lincoln LS coil packs are the two conductor type vs the Jaguar 4.0L using the 4 conductor. So that doesn't work.
Using another parts site and searching on the part number produced only '99 - '02 Jaguar applications. Guess we are stuck but the Rock Auto site did have them for $66.
AJV8s were introduced with 2-pin coils and separate ignition control modules, then upgraded to 4-pin coils and no separate control modules. The split occurred appoximately around the AJ26 to AJ27 shift, but I am unsure if it changed exactly at that time because there was a 2000 MY engine management upgrade. In Fred's car (98) it is surely 2-pin coils if the engine is original. I don't know if the Lincoln/T-Bird used 2- pin or 4, or both with a changeover.
1997-1998 are 2-pin coils for sure(shared with the XJ of similar years). When I was doing research to replace two of my coils, I noticed that it changed to 4-pin in 1999.
Now, the question is.. Are they interchangable with lincoln LS coils?? I would LOVE to replace the other 6 used ones...
volkris (01-10-2019)
hey i'll chime in.when i got my 99 xk8,it ran good for 2 blocks.drove it home and got my son to look it over.it turned out to be a coil.ordered one from local parts store.took 3 days,well it was listed as a 2 prong and i needed a 4 prong.so the change is somewhere in the 99 model year. had to be sent back for correct one..steven
I have been doing Jaguar XKs for about 6 years now and I have never seen the coil pack you are showing on the left, which throws back to my statement of "I have never come across a 4pin 4.0........"
Even my own late MY2000 XKR has 2 pin, I have worked on 2002 MY XKs with only 2 pin, all I can say is this must be peculiar to the US, as far as I am concerned 4 pin didn't come in until the 4.2, this is why if you do a 4.0 to a 4.2 engine swap you have to use your old electrics/ancillaries and coil packs.....Curious..
@xkracer
Interesting, as far as I know the 4 pin came with the AJ27 engine, so from 1999 for the NA cars and 2000 for the SC cars (my late my2000 has 4 pins). I just double checked with the JTIS electrical diagrams, and that shows the same. Could this be just a british thing ???
The AJ33/34 (so 4.2 engine) has also 4 pin, but is different again (digital iirc), so that is why you need to reuse your 4 pin from the AJ27.
Have not yet seen an AJ28 engine, so can't comment on those coils.
