Ignition coils
It’s kinda hard to tell if the one on the right in the picture is an AJ26 2 connector or AJ27 4 connector coil, as you can’t see the pins. Only way to check is to take of the ignition cover and count the wires going in the coils, it would be interesting to find a 2000MY (so vin Axxxxx) with a AJ26 engine.
Nce Kty (12-21-2010)
volkris (01-10-2019)
my code reader says I have a misfire on cylinder 3 replaced all plugs on passenger side and swapped the coils on 2 and 3 now code reads cylinder 2 so I figure bad coil. found one online from Walmart for 17 dollars and s/b here next fri will post after it arrives and have it installed as to the results.
SD96XJ6L
11-05-2015 10:47 AM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
