Ignition Key Flap Gap ?
Old 09-27-2018 | 06:45 AM
Jon89's Avatar
Default Ignition Key Flap Gap ?
We know that when these infamous ignition key metal flaps get sticky and do not close properly, various electrical problems can occur (especially a continual battery drain). My question is this: How far does a properly-functioning key flap close? Halfway? Three quarters of the way? All the way?
I ask this question because I am dealing with a door lock / door handle problem that my wife's 2006 XK8 has been exhibiting for a couple of months now, and I am wondering if the fact that her key flap is not closing completely when the key is removed from the ignition switch may be causing that particular issue....
Old 09-27-2018 | 07:01 AM
Jon - on my 2000, the key flap closes 3/4. Anything less, it chimes and a quick tap under the ignition switch will release
The following 3 users liked this post by sklimii:
Jon89 (09-27-2018), RJ237 (09-27-2018), toaster (09-27-2018)
Old 09-27-2018 | 11:57 AM
Jon89's Avatar
Anyone else?
Old 10-01-2018 | 09:44 PM
zray's Avatar
Originally Posted by Jon89
Anyone else?
mine closes about the same, estimated also to be 75%.
Z
Jon89 (10-02-2018)
Old 10-02-2018 | 01:52 AM
B o B's Avatar
And mine. (about 75%)
Jon89 (10-02-2018)
Old 10-03-2018 | 06:28 PM
XK8 Comfort's Avatar
Mine too! 5's a charm
Jon89 (10-04-2018)
Old 10-05-2018 | 09:59 AM
Ophitoxaemia's Avatar
Also 75% here.
Jon89 (10-05-2018)
Old 07-22-2020 | 04:43 PM
Lori Zamora's Avatar
Default My x type 2003
Same issue bought this car two days ago and I didn't know the level of security these cars have I mean I do just didn't really think about it so when I took it for test drive i i couldn't turn key so I asked the guy why and he says I it's just sticky you kind of have to push it and jiggle it a little so we did and it worked. I bought it and since then it's gotten to point to where the flap is totally open can't turn it pay o it's pissing me off how can I reset this feature and get this thing to turn the ignition over anyone have any ideas or know about this before I have to call jaguar and spend a **** ton of money?
Old 07-22-2020 | 06:21 PM
Might try dusting the opening with powdered graphite..
The following 2 users liked this post by XK8 Comfort:
DavidYau (07-23-2020), ozbot (07-22-2020)
Old 07-22-2020 | 06:50 PM
fmertz's Avatar
Sounds like a problem with the key. Check the classifieds for the vendor selling TIBBE 8-cut keys and order one or more mechanical key to see if a new key would rotate better. Issue could be that the internals are worn out too (this is uncommon) and new keys will not help. Does the key look worn out? There should be 8 positions, each with one (of 3 possible) sloped cut.
In my experience, the key "sticks" when the steering lock is engaged. Otherwise it is easy/smooth to rotate the key.
Best of luck, keep us posted.
PS: Do not post a picture of your key as someone could order a copy...
Old 07-22-2020 | 09:26 PM
ozbot's Avatar
This happens on my F150 some times. Try turning the steering wheel a little while turning the key.
+1 on the powdered graphite.
Evoking
12-18-2021 09:58 AM
Chuck Schexnayder
10-01-2017 02:04 PM
Kimbene
01-03-2015 12:50 PM
his196
09-25-2014 02:52 PM
Fairlane500
07-26-2009 11:06 AM
Quick Reply: Ignition Key Flap Gap ?
