I'm replacing the secondary tensioners on my XKR and came across something odd
Old 06-12-2011, 04:02 PM
David's XKR's Avatar
Default I'm replacing the secondary tensioners on my XKR and came across something odd
So far I've pulled the valve cover off the pass. side. After I cleaned up the cover I noticed that one of the bolts was different because it was separated from the sleeve. It's different from all the other bolts. It's a brass color instead of black and does not have a tapered end like all the others. Is this right and if yes, were does it go? My first thought is someone had it apart and lost the correct bolt and put this one in. Also there was a lot of oil in the spark plug chamber closet to the front, less in the others and none in the one closest to the firewall.
Old 06-12-2011, 04:47 PM
hlgeorge's Avatar
Year and model??
Old 06-12-2011, 05:06 PM
Received 8,059 Likes on 4,863 Posts
The different bolt/spacer is installed nearest the CMPS (Cam Position Sensor) in the cam cover.
bob gauff
plums (06-13-2011)
Old 06-12-2011, 07:07 PM
Originally Posted by hlgeorge
year and model??
2000 xkr
Old 06-12-2011, 07:10 PM
bob gauff
Wow, I was sure it was the wrong bolt. Great help, but I don't know where the CMPS is or what it looks like. Of course I know I should have been aware of the bolts as they came out, but I thought the only ones that were different were the ones with the extensions.
Old 06-12-2011, 08:03 PM
CMPS is in the cylinder head at the rear on the inside behind the intake manifold.
I just looked at your post and saw that you have a supercharged.
You will not have a CMPS but that bolt/spacer goes in the rear inside hole (toward the engine valley).
bob gauff
Old 06-13-2011, 12:48 AM
hlgeorge's Avatar
Oil in the spark plug chamber is solved with new cam cover ring seals. I would replace all the seals on the cam covers at this point.
Old 06-13-2011, 03:43 AM
plums's Avatar
Received 2,181 Likes on 1,621 Posts
bob gauff
Argh! What happens if the wrong bolt gets put into that hole? Is that particular hole shorter? Will it bottom?
Old 06-13-2011, 08:02 AM
Sorry about the not having a CMPS. You have the CMPS but not the VVT. The bolt is a different material and is near the magnetic CMPS so I guess the material is less interfering with the sensor and reluctor. I have seen hundreds of cars with the bolts in the wrong locations and have never heard of any faults.
bob gauff
Old 06-13-2011, 08:46 AM
Thanks for the info. I just got done working on the drivers side. The bottom back bolt and dipstick bolt was fun. I'm not sure how to release the clip for the hose on the upper front part of the cover, any help would be great, thanks. I noticed that the front upper bolt has the extension on it like the dipstick and fuel rail bolts. But there is a nut or any sign of why it's like that. Am I missing something?
Old 06-14-2011, 08:12 AM
Here is the special tool to release the clips.
bob gauff
Old 06-14-2011, 08:19 AM
bob gauff
Thanks for the info and picture. No wonder squeezing the clip didn't work. Of course I ended up breaking it, but at least I got it off.
toronadomike
08-07-2022 03:41 PM
Beardy
09-18-2015 10:00 AM
tberg
09-07-2015 07:32 AM
Sprayall
09-03-2015 07:49 PM
TC Johnson
09-02-2015 09:30 AM
Quick Reply: I'm replacing the secondary tensioners on my XKR and came across something odd
