inconsistent, jumpy acceleration - need advice
Hello and thanks for reading. I need some advice about my 2000 XKR.
I've owned this beautiful automobile for about a month, and I've begun to notice that the acceleration is not very linear or consistent, and is in fact rather jumpy while getting up to speed.
At times the car does not seem to pull out the power that I'm sure it should have.
Do any of you have experience with this? Amy suggestions or advice as to what I should be looking at, before I take it to a service center?
Thanks!
Thanks!
An update on my concerns here.
Took it to the Jag shop and there were no codes. It also hadn't acted up the day prior or for the service tech during a test drive.
Possibilities the tech noted as a cause of misbehavior were:
Rear tyres are at the wear mark.
Aftermarket cone filter.
Traction control cutting the power.
It's hard to say without a code or at least some more context for when the problem occurs.
If it were the traction control you should see a yellow light on the dash indicating that it has kicked in.
Does it matter how long the car has been running? A cone filter on the engine bay sucks hot air, so as the engine warms up you may notice a decrease in power.
Another thought might be a failed intercooler water pump. Similar behavior, the longer the car runs the intercooler water gets hot and power decreases, maybe even to the point of detonation occurring.
When they key is on and engine off, you should hear a whirring sound from the right front of the engine bay, below where the air cleaner is.
Camnelson324
09-27-2015 08:48 AM
Woznaldo
09-26-2015 11:02 AM
