increase the power of the original BREMBO brakes
my car ( XKR 4.2 year 2005 with 20" wheels) has Brembo brakes with drilled and ventilated discs.
I would like to increase the diameter of the discs (front and rear) while maintaining the original Brembo brake calipers.
Do you know if anyone has done this?
Standard brake discs on the 4.2 are 305mm diameter Front and Rear whilst Brembo are 355mm Front and 330mm Rear.
I understood the limiting factor on diameter is clearance within the wheels apart from the fixed Brembo caliper making any increase in disc diameter difficult.
I'll also be interested to hear if anyone has fitted larger discs and what benefit this achieves in combination with the original sized caliper and pads.
User 070620 (01-14-2013)
Jag#4 (01-12-2013)
Hope this helps
NikasilNik
Stopping distance obviously is primarily from the tires (for street the Michelins Pilot Super Sports are great for this, including acceleration ;-)). Braking can be improved in 2 ways, 1) that you can easier modulate the braking force yourself which helps also with a quicker response and 2) under heavy usage brake fade can occur lowering braking force on the wheels. So both have an effect on stopping distance, as they determine how quick and well the right amount of torque is applied to the rotors to handle the maximum braking force for the wheels. So this is also where brake pads play an important role.
Attached is info from stoptech that roughly categorizes some pads, so you have some idea. Also as a general rule of thumb, initial cold bite goes down for Club and more so from the race category as these are built to operate at higher temps. One exception though which is the RS15, that one has a very good initial bite already to start with, making them also usable for street conditions.
Here is friction/operating temp info from pagid:
http://www.brakes-pads-discs.co.uk/pagid/material-specifications.php
Whilst experimenting with different pads, have also experienced how important brake balance is between front and rear, so whatever you do, make sure you keep that in mind, any change to the fronts must also be accompanied with work to the rear.
