Indicator WL dim and beeper quiet ?
Aarcuda (03-12-2023)
I believe the speaker is inside the instrument panel but I haven’t taken the part yet, but I’d love to know what the part number is, or if I can geta speaker as a separate item. or match something to it that would work It’s just not that much information out there about that speaker other than it’s in the instrument cluster
The speaker is behind the binacle where you put the key in .
Being thick today but where is S97-XK8 pdf.
Now I have the new flip out radio the wife has the music on all the time so was wanting to fit a buzzer to the wiring but need to have a diagrasm.
Received 2,400 Likes
yes found it marked DI.....sadly the indicator switch connects to earth so not a conventional /easy system to fit a buzzer to ...will look at the speaker.
Looks like the cables to the indicators come from the body control module behind the glove box GY and GK
Buzzer and some diodes and we are away! Pins 2 and 3 ..at least its in the cab.
