inertia switch 2005-2006 owners please advise
wjd03 (12-20-2010)
Yes I know I am presently in Leesburg, Va I have a procedure on the fuel pump but first see if it has power and that the filter is not restricting your fuel. http://www.gusglikas.com/AutoRepairFuelPump.htm
yes, booted thing is the switch...taken directly from the JTIS CD...if you dont' have one, definitely get yourself one for Christmas...$10 from ebay. Get the 2004 edition (has the 2004 XJ8 in it), its the last CD type out there. May be listed as a Jaguar TIS item...not JTIS.
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/6950d1293081897-inertia-switch-2005-2006-owners-please-advise-image1.jpg)
2005... should be same spot.
It is on the drivers side fuse box. Open the box and look to the left you will see a black box with a rubber button on top of it. If it is the problem press down on the button and you will hear a click. If you tripped your inertia switch you would be experiencing a lot more problems. Codes like gearbox failure would come up electrical malfuntion. All kind of codes would come up and the car would not start or even try to turn.
Usually they are located in the truck jaguar is the only one that I have seen in the dash. If you are not the origonal owner it is possible the owner before you might have taken it out but i do not understand how the car would run without it. Unless he figured a way around it. The part is about 60 dollars and is a good thing to have. If you car drives I would take it to your local jaguar dealer. If it doesn't drive tell me some of the lights that are coming up in your cars dash I might be able to help you.
I don't need to post photos of where it should be. Because, there's nothing but fuses and maybe a couple relays.I know where the switch is supposed to be . It shows where it is supposed to be in the glove box manual. I am guessing the technology had changed by '05 and they were able to accomplish the task in a different manner. I am also guessing that if anybody out there has a late '05, or an '06 Jag XKR, that they will not have one in the side of the facia as well.
