Inherited XKR
Inherited XKR
It's been nearly two years since I have been an active member in this forum ever since I sold my black XK8.
Sadly, under the worst of circumstances I will become more active.
Dad died last Thursday and I have received as an inheritance a silver on black '04 XKR Coupe.
It starts up and runs well, however I have noticed a few things:
Coolant smell but no visible leak. However there is a leak because the expansion tank was half-empty.
And that darn check rear lights/cruise not available when the rear lights work just fine.
So, I'm thinking I'll have to change that switch in the footwell and go ahead and replace all the cooling system hoses and do a flush.
Also, the passenger side exhaust needs a new clamp, the wipers need to be replaced, and the driver's door needs a few new clips to be replaced.
How many cooling system hoses does the XKR have? I haven't inspected them, but I would change the radiator hoses, heater hoses, the octopus hose, and perhaps the water pump as well. I also know this car also has some hoses for cooling the supercharger.
Can anyone provide me with all the parts numbers for the hoses, clips, and clamps?
Can I use an aftermarket universal clamp for the exhaust? This car has an aftermarket exhaust that sounds beautiful.
Is there anything that I should check that is specific to the XKR?
Welcome back to the forum,
I'm sorry to hear it's in such sad circumstances.
If you don't have access to JEPC, a good alternative for part numbers is forum Sponsor S N G Barratt website:
SNG Barratt - The Ultimate Jaguar Parts Specialist
If the transmission hasn't had a fluid and filter change recently then that should also be on your priority list.
The following 2 users liked this post by GGG:
giandanielxk8 (12-06-2017),
SNG Barratt USA (12-12-2017)
Received 4,339 Likes
Gian - my condolences on the loss of your father!!
Here is the link to the SNG Barratts Parts catalog which will provide the necessary ordering info. Both SNG & jagbits are forum sponsors and offer 10% discount for forum members.
The following 2 users liked this post by sklimii:
Hi Glan--sorry about your dad.
I suspect the coolant leak might be at the fitting of the octopus hose that is right above one of the cats. I kept losing coolant and there was no apparent leak, but when I felt down at that fitting (referred to as the Norma connection) I could feel moisture. What happens is that the coolant leaks onto the shroud above the cat and evaporates so you never see anything but you smell it. I had the local shop replace the hose and it was a few hundred bucks (hose is expensive and access is difficult).
Doug
Doug
giandanielxk8 (12-07-2017)
I have a leak at the hose clip securing the coolant bleed hose to the reservoir. It drips onto a hot surface and evaporates as well, leaving the trace of anti-freeze in the air. I do not like the short section of rubber hose, to rigid plastic, to short section of hose, to reservoir design in particular, it seems bound to get brittle and break at some inopportune time.
I plan to replace the entire run with high pressure, high temperature rubber fuel line from O'Rielly's, as I can buy it off the spool at ~.38 cents a foot. I am also replacing the hose clips with regular hose clamps.
Condolences on your loss.
For now the car is hidden in my grandfather's house while I sort out all the legal BS.
Condolences on the loss of your Father, I lost mine this past February and miss him terribly!
On the brighter side, welcome back to the Forums, +1 on the SNG catalog as it has helped me greatly with correct part #s as needed for my XKR repairs. Hope your new XKR experiences bring fond memories of yor Dad.
Best to you and your family Gian.
Cheers,
BK
Cheers,
BK
The following 2 users liked this post by Hdpartsman00XKR:
giandanielxk8 (12-07-2017),
giandanielxk8 (12-09-2017)
"And that darn check rear lights/cruise not available when the rear lights work just fine."
That is a small square block up under the dash. Above the Brake pedal. If you look inside the engine bay against the bulkhead you will see two tiny nuts holding something the other side. Thats the switch. You have to be a contortionist to get to it. I lay with my back on the floor. Head on the pedal feeling the switch whilst being guided from the engine bay. Some can do it in 5 mins, I took an hour.
You wont have cruise control till its fixed.
If you google this problem its quite common on the Jags.
giandanielxk8 (12-11-2017)
giandanielxk8 (12-17-2017)
check-rear-lights-cruise-not-available-warning-63241/page2/#post1575929
Search for this: Omron D2HW-A211D
Have you checked Advance auto parts? When available (spotty at best), it is inventoried as a cruise control switch. With coupon codes, etc, can be as low as $65. If you have basic soldering skills, nothing beats those cheap new switches. That and the feel of fixing it yourself!
Best of luck, keep us posted.
giandanielxk8 (12-20-2017)
Jaguar Reno is slightly cheaper, I ordered mine this last spring for $140 plus shipping (147.08 total) and they had it on my door pretty quick.
I’m all for repairing the old switch, but keep in mind it may not be the old microswitches not working, they may be out of synch with each other.
I was looking at sgtofmarine's thread on replacing the switch, feeling confident I could make this a little project for the Holidays. However, that price for the switch is stratosferic. The cheapest I found was $155 on SNG Barratt.
Is it possible to repair the old switch?
