Injector O-Rings
I am in the process of replacing the valley hoses and securing all the gaskets and O-rings. I have a couple questions I would like some help on if someone has the answers it would be greatly appreciated. I searched older threads but did not find anything relevant.
1) There are 16 injector O-rings that I have priced them and the best I can do is about $130.00. Is there a Ford/Lincoln matching part number for less?
2) There are throttle body gasket and induction elbow seal are these available as a Ford/Lincoln part?
3) A multitude of O-rings for fuel pipe, fuel cross over and fuel Pressure regulator. Anyone have Ford/Lincoln numbers for these?
I replaced my intake manifold and used the same “O” rings and gaskets just used a good quality silicone lube. You know that you can have your injectors rebuilt. This is a link on what I did.
Rezzz (05-13-2014)
For about the same price as the o-rings you're sourcing, you can get a high-quality ultrasonic cleaning of your injectors, pre and post flow-testing, AND all new o-rings.
The vendor is Injector RX in Houston. A great service. I used them two years ago, and was very happy with the results.
You can find my thread on that service HERE. Good luck.
There is an ebay supplier that sells a complete injector o-ring kit for your car, including replacement strainers for about $33. See V8 4 0L Jaguar Fuel Injector Service Repair Kit O Rings Seals Filters | eBay
Rezzz (05-13-2014)
You can clean your own injectors very good.
I remove the injectors,so the engine will not hydro lock.
Place a rubber hose on the injector end.
Fill the hose up with fuel injector cleaner.
Blow on the hose,while using a battery and wire setup,to pulse the injector,until all the PURE cleaner is gone out the hose.
Works every time.
Works every time.
