Inlet manifold and throttle body removal
Old 02-24-2017, 12:23 AM
tomfurie's Avatar
Originally Posted by andyps
Thanks for the help everyone, job achieved today. I didn't do the heater pump in the end, really needed to get the hoses done today and didn't have chance to get one in time so I'll tackle that later in the year and hope that the weather stays warm enough for it not to be a problem for a while.
The valley hoses definitely needed doing, it wouldn't be long before the top one as seen on this picture burst - no wall strength at all and about twice the size it should be.
Best picture I've found of these hoses, thanks. I can't find these anywhere (and boy have looked) because I don't know the actual name.
What are the part numbers and where can I purchase these "Valley Hoses" for non-supercharged 4.2L V8?
Old 02-24-2017, 01:44 AM
andyps's Avatar
I got them from my local Jag dealer. Will see if I can find the receipt and look up the part numbers from it for you.
Old 02-24-2017, 11:21 PM
tsuppari's Avatar
Jaguar electronic parts catalog says for names:
Heater feed hose
Heater return hose
Numbers from (non SC)
Vin A30645-> AJ86326 & NNE3946CA
Vin between A00083 & A30644: NCA3945CD & NNE3946CA
motorcarman (02-27-2017)
Old 02-27-2017, 08:02 PM
brgjag's Avatar
call Jagbits or SNG, both sponsors here and say you need the VALLEY HOSES, they will know what you mean.
Old 02-27-2017, 08:22 PM
Received 8,076 Likes on 4,871 Posts
The hoses pictured above are for a NA 4.0 XK/XJ.
The 4.2 liter engines have different hoses under the intake.
The S-Types 4.0 also has different hoses.
bob
Old 03-02-2017, 12:10 PM
tomfurie's Avatar
My 2004 VDP VIN ends with G10859, and was built in 2003, so it's a very early model of the "new" platform. I always have to be careful when ordering parts.
Old 01-23-2022, 05:37 AM
galearmstrong's Avatar
This is an old thread and the hoses were replaced successfully.
I changed the hoses on my 1999 XK8 and stumbled on a much easier/quicker replacement procedure. If you remove the 10 bolts to the intake manifold and lift up on the front of the manifold (throttle body still attached) it will lift/tilt up enough to remove and replace the hoses. I used a block of wood to hold the manifold up while replacing the hoses.
The following 3 users liked this post by galearmstrong:
DavidYau (01-25-2022), markmywords (06-05-2024), motorcarman (01-23-2022)
  #28
Old 01-25-2022, 09:22 AM
Lannyl81's Avatar
Hey galearmstrong....if you lift up the front of the intake, does that not put a lot of strain on the EGR tube?....or did you remove the EGR tube from elbow or exhaust manifold??
Old 01-25-2022, 09:38 AM
Picked up slowly while an assistant watched for clearances behind and around the throttle body. All was good…
34by151
05-06-2024 12:20 PM
Gopi Hira
09-17-2016 04:26 PM
dinop
06-14-2016 02:48 PM
rsq911
04-01-2016 11:23 AM
Hank03
03-30-2016 04:10 PM
Quick Reply: Inlet manifold and throttle body removal
