Inner tie rod end - is it easy to replace?? RESOLVED
#41
Received 4,339 Likes
started at 930 this morning installing and road tested (definitely needs alignment - pulls right) about an hour ago. Let's just say getting the power flex bushings in was a total bitch!!!! an extra scissor jack definitely helped. Tomorrow - will clean her up and get an alignment. Then look into getting paint job.
will provide more details tomorrow - this is one whipped individual
#42
If someone has to do this, I recommend you take the time - mark the angle of the control arm into the wood and cut a template, then take a piece of 1/4" steel plate and bend it into the shape of the template, screw it into place and it would provide a much sturdier surface to press the ball joint in.
cjd777 (05-13-2019)
SamOscarBrown
11-04-2013 08:16 PM
daboss085
11-01-2012 05:13 PM
