INSTALLED NEW BATTERY
HEY I HAVE A 2002 JAGUAR XKR. IN MY BATTERY WENT DEAD. SO I BOUGHT ANOTHER ONE IN INSTALLED IT. IN WHEN I ROLL MY WINDOWS UP. IN GET OUT THE CAR. IN CLOSE THE DOOR THE DOOR WONT CLOSE. SO I OPEN IT BACK UP IN THE WINDOW COME DOWN. IN THE THE DOOR WILL CLOSE. SO I LOCK THE DOOR IN THE ALARM GOES OFF. IN THE DOME LIGHT STAYS ON. I DO NOT KNOW IF I HAVE TO RESEST ANYTHING AFTER REPLACING BATTERY. BUT I NEED HELP. BECAUSE I HAVE TO UNHOOK THE BATTERY EVERYTIME..
I would suggest that you disconnect the battery and charge it in that condition. Low battery voltage is famous for causing all sorts of strange issues. Just because it is a new battery does not mean that it is fully charged.
Are you sure you do not have a charging system issue that caused the previous battery to fail? Have you driven the car enough after replacement to fully charge the battery?
i work at the auto part place. i made sure the battery was fully charged. so it should b charged to the fulliest.now i havent been driving the vehicle like that. n i check the old battery and the previous owner put a reconditioned battery in it. so most likely that one wasnt no good anyway
I had this problem when i had some audio work done, and they disconnected power for quite a while. To fix the bugs, do a 'soft' reset, by disconnecting the negative terminal for about 5 minutes. Reconnect, reprogram your windows (if a convertible), and alarm and everything else should work.
I would do a full reboot. Disconnect the positive battery cable for a few minutes. Then touch the positive connector to the negative terminal for a quick second. Reconnect the positive battery cable to the battery. You will have to reset the window 'auto drop' function as described in your owners manual, be it a convertible or a coupe. You will also have to reset your radio presets and the transmission will have to re-learn your driving profile. Let us know if it works.
Guy-Pierre Boucher
09-16-2015 05:55 PM
2000, 2002, 2004, battery, convertible, jaguar, jaguaralarm, negative, off, positive, relearn, replacement, terminal, transmission, window, xkr
