Installing DRL module location
I am getting ready to install a DRL PWM module. Where would be the best mounting location to make all my connections? The outputs connect to the high beams.
DRL Universal Module Relay Daytime Running Lights with Coming Leaving Home | eBay
Are you adding lights or just want the front fog lights on during the day?
I added a switch to the fog light relay so I can turn them on without the headlights. Works great, I put the switch in the vent plug beside the valet switch. When it's on the little light on the regular fog light switch comes on as well as the fog lights. Fog lights still turn off with the high beams so it's legal. All you have to do is switch the ground side of the fog light relay.
My understanding is that Jaguar built all X100s with DRL capability, as DRLs are mandatory in Canada. All it took to activate DRLs on my '99 U.S. XK8 was for my independent Jag mechanic to do a quick DRL programming change with his diagnostic computer from U.S. to Canada (I think a 3rd setting is for Sweden). 10-min. job for which he charged me $30.
Any reputable shop should do the same for a reasonable rate.
trosty
26
12-18-2022 06:40 PM
aholbro1
08-05-2021 05:02 AM
al_roethlisberger
09-07-2015 10:53 PM
