Instrument cluster electrical issues 2001 XK8
Ok, so I was replacing the LED bulbs, following the video posted here and on YouTube. I reconnected everything minus the knee bolster (valet and whatever the other thing is) reconnected the battery to ensure lights are working. Now it says I have no fuel and the low oil and low coolant messages are showing up.
Is it possible i didn't connect the connectors on the motherboard correctly?
I just changed the oil so I know that’s good. I had a half a tank of gas. I have a coolant leak but still had plenty in the system.
Also, and I know this has been addressed here several times. During the oil change I decided to take out the speed sensors and clean them now my ABS light is on. I’m assuming I need new speed sensors?
i hate for this to be my first post but I'm frustrated at the moment and my head hurts.
Thank you in advance.
Abs may just stay lit until you drive a few hundred yards at something like 20mph or above. I've seen it happen each time I connect/ reconnect the speed sensor wires or reset an abs fault. Give it a try, drive her around the block. (BTW its supposed to work this way = normal)
John
John
Johnken (08-05-2019)
Cbwollam
XJ40 ( XJ81 )
11-29-2017 07:07 AM
car5car
05-05-2017 09:31 AM
jimlombardi
12-01-2015 02:34 AM
LoopbackZero
08-11-2015 01:25 PM
