Intake Manifold Gaskets
Ok, I just did an intake "manifold off" replacement of heater hoses, octopus hose, etc. Everything went fine, now 2 weeks later I get a "knock sensor bank 1" code. I've read where with some deft hands and tools one can do the job without taking the intake off, but if I can't manage that, do I order new gaskets to replace the ones I just put in 2 weeks ago? The price is no big deal (only $2.02 each at Motorcarsltd.com) it's just the order time, etc. Or can they be reused?
Also, if I do have to remove the intake, is there anythign else I should do while taking care of this? Don't to make the same mistake twice!
Thanks!
And thanks to the members here I have:
Fixed my multiple coolant leaks and eventually slew the Octopus!
Fixed my door lock alarm issues
Fixed my evap valve
Fixed my ABS module
More that escape me!
Enjoyed learning a lot about my car!
Thanks!
Fixed my evap valve
Fixed my ABS module
Replace the gaskets, along with BOTH knock sensors and the two hoses that run under the manifold. Otherwise you may have to remove the manifold again in short order. As an option you may want to do the octopus hose while you are in there, but not necessary.
Call RPM auto in Costa Mesa (no affiliation, except I buy parts there) they should be able to get them for you within a day. (sometimes the same day) I have a spot I buy from occasionally in Orange, the guy there is a genius but The RPM guys seem to get the price I want every time.
Let me know if you ever need help/advice etc. I am local.
I recently did my intake twice in one week I had a cracked intake manifold that I thought was a gasket problem. When I removed the intake manifold the second time I reused the channel gasket. As for the knock sensors I replace both with the intake manifold in place. When pulling the old knock sensor out attach a string to the plug at the tower and pull the string as you pull the sensor it makes it easy to pull the plug back to the tower.
As a side note I did one in the parking lot with limited tools. Just be sure to maintain control of the nut.
I have noticed that Bank 1 might need to have the sensor mount stud removed to gain clearance for the replacement. I had to use an 'inverted Torx' to pull the stud and then I used some 'gummy mastic' to hold the stud in the new sensor. You could just use a BOLT when you go back with the new sensor.
I just replaced a bank 2 knock sensor on a 2001 XJ8 the other day and it took about 15 minutes.
You can use a magnet or a piece if stiff wire to 'fish' the sensor and harness under the manifold.
