Intake Manifold question....
Old 09-04-2011, 08:00 AM
blast20's Avatar
Default Intake Manifold question....
Hey guys,
I've been chasing a couple rich codes, and my mechanic said I have a cracked intake manifold on my 99 XK8 conv. I found a Jag parts supplier that has a nice used assembly, but he told me to be sure about the part number before he ships. That said, does anyone know if they used multiple intakes in 99, and/or if I call the dealer and give them the VIN, should they be able to give me a part number? It's a bit of work to get it taken off, and I'd like to get the part to ship asap so that it can be done all at once. Thanks for the help -
Old 09-04-2011, 08:13 AM
Dennis07's Avatar
Originally Posted by blast20
Hey guys,
I'm afraid I can't help, but am curious about something.
Pretty clear how a cracked manifold could cause a lean condition, by admitting un-metered air. But I can't see how it could cause a rich condition. Did he say?
Old 09-04-2011, 08:21 AM
WhiteXKR's Avatar
Received 2,984 Likes on 2,124 Posts
Yes, the dealer can give you the part number based on VIN in the parts catalog. I see 3 different part numbers for the 4.0. If you post the last 6 digits of the VIN I can give you the correct one. What I cannot tell you, but the dealer can, is if some of them are interchangeable.
Old 09-04-2011, 08:25 AM
blast20's Avatar
Uh, er, good question....I've been chasing PO172 and PO175 for a long time now, and I've replaced air filter, MAF, etc and still had both. Then replaced the fuel pressure regulator and PO172 went away. Still have PO175 and he said there was a leak in the intake. I guess we'll see....
WhiteXKR - last 6 of VIN are 031976 - thanks!
Old 09-04-2011, 08:40 AM
WhiteXKR's Avatar
Your intake manifold is part number NNE3002CC. It looks like they only made about 1500 cars with that manifold, then the number changed to AJ82546. A dealer website says BOTH those numbers are superseded by a new number now: AJ83963.
Old 09-04-2011, 09:00 AM
blast20's Avatar
Hmmm....interesting. Here is the info I was given on the part, nowhere near those numbers? Strange.
Numbers from the Intake Manifold:
XW93-9425-CB
XW93-9C663-CD
PA66-6F35K
Any thoughts on this being as none of those match up to any that you sent over?
Old 09-04-2011, 09:05 AM
WhiteXKR's Avatar
XW93-9425-CB
XW93-9C663-CD
PA66-6F35K
I tried those numbers on this dealer site: Direct JPLV Porsche Parts.com
and they do not come up as valid.
Old 09-04-2011, 09:14 AM
blast20's Avatar
OK, I'll do some more research. A few different suppliers on ebay have them, and they are all referencing numbers similar to the ones I sent. I guess I need to go ahead and take mine off before I do anything.
Old 09-04-2011, 09:18 AM
WhiteXKR's Avatar
I have seen before where the number imprinted on the part is not actually the number the part is sold under...that may be the case here.
Poet
06-07-2019 07:54 PM
xjrjag
10-12-2015 03:16 PM
Johncy2000
10-02-2015 01:05 AM
BSM
09-25-2015 05:00 PM
Quick Reply: Intake Manifold question....
