Intake Torque specs, what are they? 03 XK
Old 10-13-2014, 08:39 PM
brgjag's Avatar
Default Intake Torque specs, what are they? 03 XK
I have looked for a good bit and can't find any pdf or the like on the site for bolt torque specs for the intake I have to put back on my car, the specs for the TB, all that stuff. Really anything of the like for any bolt on this damn car.
djpxk8 (11-07-2014)
Old 10-14-2014, 05:21 AM
plums's Avatar
Received 2,181 Likes on 1,621 Posts
JTIS or the engine repair course manual.
No one except maybe Brutal or Motorcarman is going to know this without referencing the above references.
It's far safer for you to look it up than to depend on someone else to transcribe it accurately. Even if they did, how would you know?
djpxk8 (11-07-2014)
Old 10-14-2014, 11:16 AM
brgjag's Avatar
"JTIS or the engine repair course manual."
I thought I saw links here for these to PDF's which I can't find.
djpxk8 (11-07-2014)
Old 10-14-2014, 07:39 PM
brgjag's Avatar
I found a online manual for 2003 and up, prob some of it can used for prior to 2003???
Has all my specs for torque on bolts when I put the intake back on.
djpxk8 (11-07-2014)
Old 10-14-2014, 07:42 PM
plums's Avatar
They are likely close.
JTIS download link is in the stickies.
Engine manual is in various links of posts by Motorcarman.
The advanced search is much more useful than the quick search.
djpxk8 (11-07-2014)
Old 10-14-2014, 08:25 PM
brgjag's Avatar
It is hard to find some things here, there is SO much to sift through, diff descriptions, or I don't know the right names for things. I am finding that googling things is easier at times.
djpxk8 (11-07-2014)
Old 10-15-2014, 02:43 AM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
djpxk8 (11-07-2014)
Old 10-15-2014, 05:58 PM
michaelh's Avatar
Received 2,386 Likes on 1,548 Posts
JTIS gives:
TB -> elbow 18-24 NM
10 x inlet manifold bolts 22 NM
djpxk8 (11-07-2014)
Old 11-07-2014, 03:50 PM
djpxk8's Avatar
Angry
Just snapped the middle bolt !!!!!!!! before putting anything like 20NM on it, does this mean it was just a bad bolt???? will I have stripped the threads in the Aluminium!!!!
What a great day!!!
Old 11-07-2014, 03:56 PM
brgjag's Avatar
Now are those specs I am finding for the 8 bolts that go in THE TOP of the black plenum that holds everything on the intake down set up. The stuff I look at is not that specific.
Those little bolts do look like they would not handle much.
djpxk8 (11-07-2014)
Old 11-07-2014, 04:20 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
When I reinstalled my manifold I installed all the bolts first (finger tight) for proper alignment of the manifold I then snugged them all down then torque them to specs. Hard to see if the bolt was cross threaded but I hope you did not mess the threads up.
djpxk8 (11-07-2014)
Old 11-07-2014, 04:24 PM
djpxk8's Avatar
Red face
MY FAULT, MY FAULT, I appologise I set the Torgue wrench incorrectly it was in KGS!!!
So I converted the 20NM to 15ftlbs and redid the inlet manifold torqued down and they are now OK, except I will need to get a new bolt tomorrow and HOPE that the threads are OK and the new bolt will torque down OK.
So SORRY to have been such an alarmist, but you know how it feels when things go wrong!!
Gus (11-07-2014)
Old 11-07-2014, 05:23 PM
plums's Avatar
Please remember that almost every torque wrench is accompanied
by instructions that specify the usable range of the wrench is
between the bottom 20 percent and the top 20 percent of the
nominal range.
A 250 ft/lb 1/2 inch torque drive wrench would not be suitable for the fasteners
being discussed.
djpxk8 (11-07-2014)
Old 11-07-2014, 07:38 PM
brgjag's Avatar
Well I have mine in and all buttoned down. Fired right up. No leaks that I can tell. I had a check engine light when I shut it down to do the repairs, weeks later with batt undone, fired it right up and light back on. Still runs fine but will check that later. The black airbox intake tube from air box to TB, in the accordion area has small holes, maybe air reading are a bit off??@!?!?!?!?!?
djpxk8 (11-07-2014)
xjrjag
10-12-2015 03:16 PM
Johncy2000
10-02-2015 01:05 AM
Glenn Barickman
10-01-2015 04:09 PM
caldoofy
09-28-2015 08:43 PM
Quick Reply: Intake Torque specs, what are they? 03 XK
