Intake valley hoses
Received 2,432 Likes
Pretty sure your 99 is the same as the 98, in which case you don't need to separate the injectors.
You will, however, need something to disconnect the fuel lines:- either (1) in Fulton's list or, if you're a cheapskate like me, a short piece of 15mm plastic plumbing pipe cut lengthways.
If you're not replacing the thermostat tower, do take the opportunity to replace the two rearmost bolts with hex-head capscrews, or file a slot across the heads to ease removal when it does let go.
Item (3) in Fulton's list will help with the clips, but I'd add clean paper towels and some antiseptic cream to the list
HTH,
Mike
HTH,
Mike
