Interesting Training Document on the 6HP26 Transmission
I found this when I was looking for info on the ZF 6HP26 transmission. It's actually a Ford document, but it goes into a lot of detail explaining the workings of the transmission which is used in Lincoln Navigators as well as the 2003+ XK8s. The good stuff starts on page 3-40
http://www.motorcraftservice.com/vdi...es/30n29f0.pdf
Looks like (per page 3-50) to replace the fluid you drain, remove the pan, replace the pan with a new one, replace the pan and fill. You have to replace the pan because the transmission fluid pan, gasket and filter is a one-piece assembly. Is this the only "maintenance" you can do to the trans? I wonder how many miles it makes sense to do it?
Reading about all the controls, solenoids, etc. - this is really a complex piece. Remarkable that it is a reliable as it is. Good thing too.
Jack
Jack
aholbro1
08-05-2021 05:02 AM
FS[SouthEast]: Parting out 1994 Jaguar XJS Coupe - 6 inline
rama1200
20
12-03-2015 11:00 AM
