Interior boot open button and remote button don't work
Hi all.
The interior boot open button and remote button don't work. It's not in valet mode as when it is in valet mode and I press the release button the display tells me off.
I've put a voltmeter on the connector and there's zero volts when the button is pressed. I've checked the fuses in the boot and the drivers side.
Any other idea?
Thanks and happy Friday to you all.
Any other idea?
Hi all.
Any other idea?
Any other idea?
Have you tried using the key to open the boot ? This resets (cancels) the valet mode, just in case it is in effect whether or not you have pressed the valet button.
Just a hunch Looops, as your problem is to do with the electrical side of the operation, look at the loom that goes from the boot to the boot lid. You may have a broken wire in that part.
Does the button on the boot lid work or not?
I can't remember if there is a relay in the boot or not, but may also be worth a check.
Hope this helps,
Jim
Hope this helps,
Jim
BrentGardner
28
04-26-2024 03:08 AM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
Ziggybeben
08-30-2015 02:09 PM
Andrew McVey
16
08-27-2015 07:21 PM
