Intermittent Fuel gauge issue
Hi All,
I have a 2000 XKR with an annoying problem.
The fuel gauge will be reading the correct level when it will drop to empty for no reason at all.
This occurs at random and it returns to normal at random as well.
Has anyone experienced this or knows what the fix would be.
Thanks,
John
Thanks,
John
Hi All,
Thanks,
John
Thanks,
John
The following 3 users liked this post by Paul Pavlik:
There are 2 possibilities. One the fuel sender itself is going bad and second you may have a loose/damaged connection at the sender unit. You can inspect and or change the unit without pulling the fuel tank. When the carpet is removed at the forward bulkhead in the trunk the unit is easy to locate on the face of the tank. You need to be sure the fuel is low so that you can remove the unit if necessary.
Just what Paul said. Posted 2 minutes ahead of me. LOL
Jestocost (11-14-2018)
asleach2889
03-13-2016 09:07 PM
Tman
08-23-2015 06:56 AM
raygin
08-24-2010 06:20 AM
