Intermittent stalling
Hey Everyone!!!
The car has been Fantastic and Fun to drive,,, And no problems to speak of till now... The otherday I was driving around town and was stopped at a light when the car just CUT OFF,,, Started right up no problem. Drove fine the rest of the day. The wife(PBTW) said that it happened to her twice before...
Any IDEAS???
Thanks in advance
Da Count
Any IDEAS???
Thanks in advance
Da Count
This kind of behavoir could be a weak relay in the ignition or fuel pump circuit, possibly even the main ECU relay. When a relay fails, it does not trigger a code just for that. How many miles on the car? Fuel pump relays take a beating. I am assuming that the cut off was not accompanied by any rough running or other odd behavior. I would replace a few key relays as an experiment, as well as remove , clean, and reseat the ECU harness, maybe pull the throttle body connector and clean it. Sudden running failures can often be the crank position sensor too, so keep an eye on it.
There's an old English (and, naturally, totally non-pc) adage
'Women, meat and the Walnut tree
All the better for a beating be'
The walnut tree bit is interesting - it was customary to plant a walnut tree on the birth of the first son so his son could have a gun stock made from it.
Beating the tree with an iron bar improved the 'figure' in the grain of the wood.
While I most definitely disagree with the 'Women' bit I think you could safely replace it with 'Jaguars' - a good thrashing does 'em good - so go to it !
"Beating the tree with an iron bar improved the 'figure' "
The Iron bar could disfigure your meat...
So that is why I PREFER a more natural tenderizer such as PAPAYA JUICE... Bon Appetit
Now if you were a VEGETARIAN you could SNAP YOUR CARROT
TB needing a clean would be my first move but, if the battery has been disconnected, have you followed the throttle 'learning' procedure?
Check this link:
https://www.jaguarforums.com/forum/x...connect-74146/
The 'learn' procedure sets idle and kickdown positions.
Check this link:
Be careful before installing a pump. The system in this model also has a fuel pressure sensor on the engine and a control module that could be bad. This mileage is awfully low for pump failure. Also, the failure mode is not normal for a bad pump. They usually only quit once, not off and on due to failure being windings melt down. My guess is the sensor or module since the restart/reboot got it running again, the way computers poop out.
Also, welcome back Count, we missed you!
Mark
Gave the car a complete Physical and EKG,,, The fuel pump was Flat Lining,,, So we took it out and Sure-Nuff is was dead infact the 2 top connections showed signs of the pump running hot...
The Jag Dealer replaced it at 20,000 miles in 2008,,, The fact that it sat for so long (I purchased the car 11/15/2011 22,000 miles) was most likely the reason for the failure..
Pump $1100.00
Seal $ 59.00
Cover $79.00
The Rise I get from DRIVING IT.... PRICELESS
Pump $1100.00
Seal $ 59.00
Cover $79.00
