Intermittent working alpine radio and separate NAV unit on 05XK8
Please help, I have an 05XK8 convertible with the original Alpine stereo stock power antenna and separate NAV unit located in center of Dash instead of the three analog dials. Most of the time the radio nerve unit are in operable and sometimes when driving I’ll press the power button to the radio and it will come on and everything works as it should including the power antenna and the separate navigation unit. When I turn the car off and go to drive it again it is again an operational. I remove the consul and check the wiring for both units and everything appears normal. As anyone knows that has this car there is nothing to indicate what fuse goes to white. Personally I don’t think it’s a fuse because it works intermittently. Is this connected to the ignition switch somehow anybody have any suggestions please help I love my XK8 and it sure does make the experience much more pleasurable with a working radio and personally I do like the look of the clock when the NAV unit is operational. Thank you for again for any help
On an 05 xk8 The underneath of the lid of the fuse boxes do not have fuse diagrams unfortunately. I inspected the wires visually disconnected them and plug them back into the radio unit and NAV unit to make sure the connections were clean I don’t know how to use a voltmeter so I’ll have to Google it and buy one. I thought maybe somebody else might’ve had a similar situation. It’s funny because the NAV will work if the radio is working but if the radio isn’t working the NAV isn’t working can you tell me where the fuses are located for the radio separate NAV unit
Received 1,674 Likes
so I just bought the cheapest eBay (exact) amp that I saw , $32. I got lucky and that fixed the issue..
if you do go for a used amp lime I did, take your existing amp out and look it over closely. Only purchase an EXACT duplicate . Getting the same model number is crucial to having a happy ending.
Z
I’m happy that worked out for you and for only $32 I hope I’m that lucky or maybe I just have a loose wire or something to the amp, that’s my project for tomorrow. Thanks again I appreciate your replies this is such a great forum. Would you happen to know where I could get a diagram of all the fuse locations and what they control? For some reason on the inside cover of my fuse boxes they do not have A fuse diagram
A loose cable come out of the in-dash head unit can give intermittent no-sound / no nav unit power . On my ‘02 I could pull the carpet away from the driveline tunnel and get my hand and also a little light from my iPhone up to the rear of the radio and wiggle all the connections coming out of the unit. They were tight, so I then focused on the in trunk amp, which is a bear to get it and it’s frame out for examination.
there are many used amps on eBay for $50 to $100 , most of them are “no returns accepted”. But the prices are so attractive that I didn’t mind taking a chance.
Z
DavidYau (04-24-2020)
I already removed the consul the radio and the NAV unit and checked all the connections and they seemed fine but the consul needed a good cleaning so it wasn’t in vain. I’m hoping it’s a loose connection to the amp or just the amp like it was for you. I appreciate you sharing Your issue and solution I would’ve never thought it was the amp.
Lincoln Colt
04-24-2020 08:36 AM
Clockwizzle
01-10-2016 04:59 PM
Shadow993
02-13-2012 09:15 AM
