Ipod use in a 2000 Jaguar XK8
Received 4,302 Likes
I've moved your post from the forum feedback/advice which is for issues with the forum itself to the XK8/R section for better visibility.
As for connecting the ipod, do you know if you have the premium Alpine system or base?
This will work with either Alpine premium or base, connects through the cd player but disables use of the cd player as the ipod is now the audio source: iP-JAGCD iPod Adapter for Select Jaguar with CD Auto Changer :: iPod Adapters & Interfaces
If you have the premium Alpine system and wish to retain functionality of the cd player, then there is one other option (I chose this one very easy to install/use) JAG-CDR (from the same website although it currently shows as out of stock.
2002 XK8 Convertible.
I have converted all my other cars over to use IPod/Android/MP3 devices that play thru the CD changer inputs (Audi, VW, Ford and Buick).
Of course nobody had anything similar for the Jag!
This is what I did:
1: iSimpleSolutions.com has the Tranzit BLU HF.
It connects between the radio and the antenna and plays through a radio frequency you choose. Tranzit disconnects the antenna when you are using it and reconnects when you want to use the radio. It is Bluetooth, gives hands-free calling through a supplied microphone and has a small surface mounted control. It has worked great and keeps Jag looking stock.
2: Pro-Fit-Intl.com has a device holder bracket (JG-51-97) that is specifically designed for our car. It is secured under the wood and extends to the right of the console. You also need to purchase a holder for your phone that mounts to the bracket.
3: Temperaturealert.com has a 12VDC to USB adapter (AC-12VUSB100) that replaces the cigarette lighter socket. The lighter power is switched on with the ignition, so all you have to do is connect + and - with spade connectors.
This brings our British Motoring Experience into the 21st century!
Best of Luck; Neil
This is what I did:
Best of Luck; Neil
Parrot MKi9200 blutooth hands free car kit for phone and digital player connectivity.
Just had it installed in my 03 XK8 convertible under dealer recommendation and supervision.
Full hands free voice activated phone that works thru the full OEM audio system
Also has full iPod IPhone Smartphone MP3 player audionconnectivity
Instead of spending $100 on the cable, I made my own by hacking up an old ai-net cable and the female ai-net plug from an old broken alpine cd changer. Instead of connecting it to an Ipod cable I have just used female RCA plugs, and I have this connected to either my ipod or phone using an RCA to 3.5mm headphone jack.
The cable is connected between the back of the headunit, and the original ai-net cable in the car.
I'm pretty amateur when it comes to things like this, but with the help of a multimeter and some heat shrink, it's come out pretty well, and the rca plugs give me a bit more flexibility than an ipod only plug.
Google ideck cassette adaptor. It has an iPod Dock that sits at the front of the existing cassette player. I bough one not expecting it to work very well, but it surprised me. Very we'll made, sounds great and very neat.
I used the cable and built a docking station into the ashtray. Works like a charm and it charges the phone as well. With the door to the ashtray you don't see a thing. Picture below:
Attachment 79665
Attachment 79665
How did you do this?
Thanks PaulCarr for the info but my car does not have a casette player so this solution cannot work.
I was wondering if there was a way of routing the audio out of a generic 3.5mm jack in parallel with the CD Changer output with a parallel switch or something and then ...![Icon Band](https://www.jaguarforums.com/forum/images/smilies/icon_band.gif)
![Icon Dance Twist](https://www.jaguarforums.com/forum/images/smilies/icon_dance-twist.gif)
PaulCarr (10-15-2014)
I need a nudge with the IP-JAGCD (I bought it used on eBay) for my '06 XK8 convertible. The instructions show an amp-over-CD assembly that ideally is unfastened and tilted down. On the convertible, though, part of the roof hydraulics is bolted to this assembly. Is there an easier way to do the install?
DrOrb (07-12-2015)
cyber3d (07-20-2015)
