J Gate replacement part
The selector lever illumination module includes the cover that is cracked (Jaguar does NOT sell the cover separately) but............ There are different illumination models for the different gearboxes.
That is a 5 speed gearbox selector but.................They are different between the NA and SuperCharged.
The cover probably can be used from any 5 speed selector but you would need to disassemble and only use the cover if the selector part number is different.
The selector lever illumination module is actually a module on the CAN bus so a correct one is required. The plastic covers can probably be swapped? with even an incorrect module?
Part numbers for the X308 sedan are the same as the X100 for the 4.0 liter cars so that gives you more options for salvage parts.
ZF 5HP24 selector illumination module = LJA6195BG is the superseded part number (also LJA6195BE or BF)
W5A580 selector illumination module = LNC6195AC is the superseded part number (also LNC6195AA or AB)
