jag 1998 xk8 abs track control fault
Hello all ,i no this has been covered many times,i have the abs warning light on and track control on dash,ive fully charged battery and check all conection on speed sensors removed them all and cleaned them all,i was gonna look and ecm module but noticied it has weird shaped screws on lid, not star ones,ware do i get this tool,i was gonna just unplug ecm n check connection of link harness.i no u can buy the ecms very cheap now on ebay for xk8 1998,if i do a straight swap will it be ok,ive had this fault for seven years but it usually goes away,this time its not,i no u can open up ecu and resolder but dont want to,i have disconnected battery and checked for any fault codes on my little code checking machine all is clear,main thing i want to no is how do i get to link harness from inside the car,kind regards
in the end i used a company called blackcountry jaguaR who i sent my faulty abs module too and they repared and returned it same day ,excellent service and only 60 pounds all in,when i fitted it abs light and track control lights were both out{first time in seven years,i did have to bleed breaks ,very easy,so good end result,very easy job to remove abs module,removing windscreen washer filler made it alot easier,
Hello all,
I no this has been covered many times.
I have the abs warning light on and track control on dash. I've fully charged battery and check all conection on speed sensors, removed them all and cleaned them all.
I was gonna look and ecm module but noticied it has weird shaped screws on lid, not star ones. Ware do i get this tool?
I was gonna just unplug ecm n check connection of link harness. I no u can buy the ecms very cheap now on ebay for xk8 1998. If i do a straight swap will it be ok?
I've had this fault for seven years but it usually goes away. This time its not. I no u can open up ecu and resolder but dont want to.
I have disconnected battery and checked for any fault codes on my little code checking machine. All is clear. Main thing I want to no is how do I get to link harness from inside the car?
kind regards
kind regards
Please use line breaks. A solid block of text is VERY hard work to read!
Are these the fixings you mean? (RH side already removed in this pic):
If so, you can release and refit them with a broad bladed screwdriver.
Enjoy the moment. it's not often you have the chance to link the words 'easy' and 'fix' when it comes to Jaguar modules.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
NinoGrimace
08-26-2015 05:15 AM
