Jag Experts: Can I use the blue BMW anti-freeze on my '05 XKR?
The Ford (aa Jag) and BMW are of the same type so you could use it. As you probably know the BMW spec isn't easy to find, so you could easily sell it off and use the proper Ford coolant.
Have a read here Coolant/Antifreeze
You could probably use any modern anti freeze as long as you change it often enough.
Ford , Mercedes Benz and Chrysler use G05 chemistry. GM uses Dexcool and Toyota, Honda and BMW also have their own formulas.
These formulas came in the late 80's and early 90's to meet demands for extended service intervals as the traditional green stuff was found to cause corrosion on alloy components if it was not changed. But even the green universal stuff is pretty safe these days.
Beardy
09-18-2015 10:00 AM
