Jag to South of France
Made it down to the South of France in the XK8. Day one saw us motor to Folkstone for an overnight stop, then bright and early start onto Longemer over on the Eastern side of France on the German border. After a fabulous days motoring on the routes National towards Chambery, we found ourselves amongst some sort of Cannonball run with every exotic sportscar ever made (Modball) tear arsing about. After a really fun bit of mountain driving (Not really pushing it) we encountered a road closure, which had us traversing mountains at a snails pace, up some sections which were dirt tracks, at this point, I had the engine failsafe light come on for a few seconds, then it went out. I stopped to check out a hotel, the Jag was running really rough at tickover, vibrating and not wanting to keep going. We decided to stop for the night, and I called my breakdown service (ADAC) who said they would send a mechanic out the following morning.
Mechanic duly arrived, loaded the car onto a transporter, and drove us to a Renault garage who helpfully advised us that the Jag was a Jag, and not a Renault. The car was running fine so we decided to press on to Castellane via Geneva, as there were Jag dealerships in Switzerland.
Another 400 odd miles were achieved without incident so we decided to carry on with our well deserved holiday.
The last leg of the journey, took us back up into the Alps, through the Gorges Du Verdon, a spectacular part of France. We stopped at the Point Sublime in the gorge to sight see, and I noticed I was switching off just as the radiator fans cut in. When I turned the ignition to start away, engine failsafe light came on briefly, then extinguished as we moved of, coming on briefly again a few minutes later. The car is running beautifully apart from this little glitch with the engine failsafe mode light, I'm wondering if this is just the top of the engine getting hotter than the gauge tells me momentarily before the air flow cools it back down. The Jag has used no oil or water the whole trip and has run faultlessly apart from the day 3 instance. Anyone else experienced similar issues?
Sounds like an amazing experience.
I would encourage you to check the OBD codes for these errors. For lack of a better plan, get a cheap ELM327 with Torque Pro for a few $ each. Get the codes. Also, get the "realtime" details, in particular the fuel trims.
Best of luck, keep us posted.
Ozarks XK8 (06-30-2017)
The roads down here are quite outstanding. The only thing which could improve things would be a manual gearbox. We are staying in a tiny village near the Lac Du Sainte Croix, guess what I passed in the village? An XKR, first Jag I've seen in France besides the one I'm driving.
Do try to check out the Grand Canyon Du Verdon there is a route to the right and a route to the left which leads to the base and the Verdon river. Both are not to be missed. If picturesque villages are your thing, I recommend Moutiers Sainte Marie at the north eastern end of the Lac Du Sainte Croix.
You could go a very long way before you see another XK8 let alone one in BRG.
In the last 20 years I've made 33 Continental driving trips totalling 77,214 miles in 454 days. In all that time and distance I've only seen an identical model car (and never one the same colour as mine) 5 times.
Oddly enough, I had the same thing 3 years ago with the MR2 Turbo, that time, the other guy chased me down, and we took photo's of the car's together (The MR2 wasn't imported to France, so it's quite a novelty) If I see him again in Aups, I will brave the possibility of being mugged off and introduce myself with a view to photographing the two cars together. I don't hold out a lot of hope though, you know how some Jag owners can be.
Well, we made it back home with the XK8 and I've had a chance to read the fault codes; one stored code P1227. I found a post on another forum which so mirrored my symptoms that I would be surprised if it wasn't the same fault. I'm thinking throttle body/position sensor as this would explain both the sudden stalling and the restricted performance/engine fault lights after the under bonnet area heats up excessively.
