jag went nuts... HELP!
Old 01-27-2009, 10:17 PM
GreenJewel's Avatar
Default RE: jag went nuts... HELP!
ORIGINAL: 2000blackxkr
I am going to go get the motorcraft one. The stock jag battery says its 650CCA.
The specs on the motorcraft is:
part# CCA CA
BXL-49 750 935
The Cost is MSRP $64.95 with a 84-month (7-year) unlimited mileage, limited "pro rated",
18-month FREE replacement Warranty.
I will let ya know when i get it how it does.
I've got 2 of these in my diesel truck.
Old 01-27-2009, 10:39 PM
2000blackxkr's Avatar
JagTech... Thank you for the entertaining banter! i should figured you would have already known that info about who makes em.[sm=bangbang.gif]
GreenJewl... thats awesome.. if it fits... i don't care what else there in. [sm=smokin.gif]
Old 01-27-2009, 10:57 PM
Right back at ya, mate. The main thing is that you didn't have to retreat to Fort Jaguar to get sorted out.
A new lesson learnedevery day makes it a good day for me. This one will end with me snow plowing the driveway...time to fire up the tractor.
Old 01-28-2009, 03:09 AM
GreenJewel's Avatar
I'm sure it will work and also save you space and weight.
The battery that's in my XK8 was made in Spain so says the sticker that's on it. It's the largest battery I've ever seen in a car. It weights about 60 lbs. I was wondering why the battery is so big. I've stood beside the car when my wife started it up and also when she shut it down and there's a lot of electrical clicks that go on.
Does a bigger battery have more load capacity so it can run more electronics than a smaller battery with about the same amp power?
Old 01-28-2009, 05:41 PM
hlgeorge's Avatar
Yes and no. Depends on the battery.
Old 02-05-2009, 09:02 PM
Default Ok more info
Ok, the motorcraft battery i stated below is no longer made.
its now BXT-49 MSRP $124.95 100month limited 36month free replacement.
But the good news for me is i only needed to put my stock battery on the charger and add a lil distilled water.
Old 02-12-2009, 07:58 AM
GreenJewel's Avatar
That's almost the cost of that 1000 amp Interstate battery that's the size of a suit case (the one that came with the Jag) and weights about 40 or so pounds.
VinnyT
69
05-17-2021 09:30 AM
Doovoe
09-08-2015 05:42 PM
joey g
US Northeast
09-07-2015 06:28 PM
MrMellor
09-07-2015 10:22 AM
Rick Michael
09-06-2015 06:53 PM
Quick Reply: jag went nuts... HELP!
