Jag XK8 ABS module removal (1997)
Having the ' well known' problems on my XK8 of the ABS warning and traction control warning coming on. I have taken out and cleaned all 4 sensors but to no avail. The next step will have to be taking out the ABS control module and re-soldering the problem areas on the board or sending it in for repair.
I am not keen on taking off the brake lines from the block and then having to bleed the system.
Anyone have experience taking the module out without disconnecting the brake pipes?
Welcome to the forums iankke,
I've moved your question from General Tech Help to XK8/XKR forum. This is the place to post technical questions about your vehicle
JagYi
04-25-2022 07:00 PM
69merccougar
01-20-2015 05:45 PM
Joedudejag
11-04-2014 11:25 AM
