jaguar claimed field service action codes?
Welcome to the forum, I've moved your post to the XK8/XKR section, this is the correct area for a 2000 model XKR.
When you get a moment stop by our new members area ==>> New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Uh oh, you're going to get yelled at by a Moderator because you posted in the X150 forum (2007-2015 Model Year) instead of the X100 (1997-2006 MY). The moderator will move it to the correct forum for you AND also yell at you for not first introducing yourself in the Newcomer Forum. Also, you are highly encouraged to add a signature block for your posts so members know what vehicle you have.
But until then, the site jagrepair.com has some info, I'm not sure if it's fully relevant.
Cee Jay (04-08-2015)
S474:
http://www.jagrepair.com/images/TSB/...20Breather.pdf
S499B:
warranty codes
Mr. Google is unaware of the others.
S499B:
warranty codes
I199, I suspect is a typo. I999 would denote the Pre-Delivery inspection claim.
S474, Service Action to clean the Part-Load Breather and add to maintenance interval thereafter.
S501, Service Action to replace EGR transfer pipe for possible cracks.
S484, Service Action to inspect IPC, and replace back cover or IPC entirely.
S499, Service Action to inspect and/or replace frt lower wishbone bushes.
S841, Service Action to replace EVAP Vent pipe for possible internal corrosion/rust.
Cheers,
Cheers,
The following 6 users liked this post by xjrguy:
Cambo (04-08-2015),
cjd777 (04-08-2015),
Lady Hirsel (04-14-2015),
motorcarman (04-08-2015),
sklimii (04-08-2015),
and 1 others liked this post.
X_Type_South_Africa
12-09-2015 05:37 PM
Fraser Mitchell
10-01-2015 04:06 AM
thedugger1
09-24-2015 05:32 PM
bhojav
09-05-2015 01:19 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
