Jaguar OBD-II Codes Please Sticky these
BoxxMann (12-16-2013)
I know you posted this with the best of intentions, but these generic Internet lists are rife with errors. For example:
"P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage" is not true. P1111 is not even a Jaguar error code, it means all emissions tests are completed.
In addition, some Jaguar fault codes change meaning depending on model and model year.
The most reliable information is Jaguar Service literature. The codes are available if you download JTIS and Gus has also posted on his site here: http://www.jagrepair.com/JaguarXK8ElectricalOBDIIcodes.htm
http://www.mediafire.com/view/kw5d9t...C_OBDII_R1.pdf
It's in PDF format.
If you ever get a code on a Jag that isn't in any of the official lists, then have a look in here
Ford-Manufacturer-Specific-DTC-2007
philwarner
12-06-2021 07:13 AM
Isoruku
06-19-2020 12:54 PM
tonimccloud
19
01-18-2020 01:56 PM
X_Type_South_Africa
12-09-2015 05:37 PM
