Jaguar XK TSB's
Old 12-16-2010, 12:57 AM
anjy834u's Avatar
Default curious
Originally Posted by mariasjaguar
No one has written that when they need to add more fluid to the hydaulic pump 1. where do you pour it into, and 2. Do you need to remove the pump or any special tools. Please advise. Thank you. Maria
i would like to know those too
  #42
Old 12-16-2010, 12:58 AM
anjy834u's Avatar
Default trims
Originally Posted by h20boy
Glad you figured it out Maria.
Also check out the Frequently Asked Question thread in our XK8 section that has a ton of useful links to other threads and some off site resources. Check out the links to the convertible top, you're needing to add hydraulic fluid is worrying me. Its a sealed system, and if you're losing it, its leaking somewhere, either the top latch, or at the rams/pistons that actually do the work on the top lowering and raising. Last time I heard a post about checking their fluid, about a week later, the owner got the 'green shower' and had to replace all the hoses.
Hope you fair better!
what trims are available with jaguar xk ?
  #43
Old 12-16-2010, 01:02 AM
anjy834u's Avatar
Default Tsb
Originally Posted by jhenryr
Thanks guys. I just fixing the head rest motors on my 03 XK8 which I bought last November. I have the TSB for that and it made the job easy. Would not have known where to start without it.
how did TSB help ?
  #44
Old 12-16-2010, 01:03 AM
anjy834u's Avatar
Default navigation issue
Originally Posted by Harley D.
Hi Gus,
Nice to hear from you. I don't really need anything, thanks.
But I spotted your post on MPC regarding the frustrating "Navigation DVD" issue -- which provided a link to this site -- and I was unable to open your attached PDF file in message #49. So I joined the Forum, and still couldn't open anything. It was while browsing that I discovered Matt's reminder to new members.
Don't know if I'll ever get to the requisite ten posts in order to obtain "permission," considering my inactivity of late. However, I still try to stay informed, and follow select topics.
Hello to all who remember me from elsewhere. You're in my thoughts, even though I'm no longer an active participant.
Harley D. - '03 XK8
Southern California
what exactly was the naviagtion issue ?
  #45
Old 12-16-2010, 08:19 AM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
The issue was that Jaguar & NavTecq are not making updated for the 1997 – 2007 GPS Navigation systems.
  #46
Old 04-14-2011, 06:31 PM
lecuming's Avatar
Do they cover TSB as warrantee fixes (assuming the car is past the warrantee period)?
  #47
Old 04-14-2011, 07:40 PM
WhiteXKR's Avatar
Received 2,988 Likes on 2,125 Posts
As a general rule, no, unless a safety recall is also involved. That is not to say there might not be the rare negotiated exception.
  #48
Old 07-27-2011, 07:09 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
Default Harley d !
How good to hear from you!
All the MPC folks are over here now.
  #49
Old 08-31-2011, 07:37 PM
Skid Mark's Avatar
Is the throttle body plug(s) TSB on the website?
  #50
Old 08-31-2011, 07:49 PM
Gus's Avatar
Gus
Gus is offline
If TSB 303-58 for the TB is what you are looking for it only covers 1999 to 2001 MY cars
  #51
Old 10-24-2011, 08:00 PM
wrgarey's Avatar
Originally Posted by H20boy
Remember, new members, with less than 10 posts and 3 days of membership (both must be achieved) cannot download or view 'attached' documents. Please read the New Member thread as the MUST READ for all new registered members.
thanks.
Maybe the rules for new members should be written as simple as you state them here. I was so confused by all the language I just put it off. Seems siple enough when stated as 10 post and 3 days as a minimum. Got It! If this isn't correct let me hear it again. Thanks
  #52
Old 03-22-2012, 01:53 AM
cbxsage's Avatar
Wow! Too bad TSB 303-30 about tensioner upgrades with customer complaints, wasn't "still" active. I assume that the factory upgraded those who complained and let the rest be "blissfully" unaware. However, it would be way cool if they would replace mine now...I'M COMPLAINING ALREADY!!!
  #53
Old 05-07-2012, 10:44 PM
barkergl's Avatar
Default Convertible Top Needs Helping Hand
I have a 2004 XK8 Convertible. The top sometimes will not raise past the high point of travel unless I give it a helping hand. When I do not give it help, sometimes there is a beep from the control system and then the top subsides. ALso sometimes it takes so long to latch or unlatch that I give it a hand.
I have read the TSB posted and other related threads. The fluid level in the reservoir is above the marks when the top is down - is this correct?
The valve handle on the pump body is firmly closed.
As it is a 2004 model I assume that it does not have the older fluid that caused gel problems.
Any thoughts on remedies?
Graham Barker
  #54
Old 08-22-2012, 02:12 AM
cbxsage's Avatar
Default Need TSB and instructions for cleaning TB.
I need TSB 310-06, Amended 10/00 on Cleaning the TB on my early '99 XK8. Can anyone help? Most appreciated.
Thanks,
  #55
Old 10-30-2012, 03:01 AM
Wrangler's Avatar
Banned
I don't know what you're saying, but it sounds very much like
  #56
Old 10-30-2012, 09:54 AM
Gus's Avatar
Gus
Gus is offline
Is this what you are looking for? http://jagrepair.com/images/TSB/310-06am3.pdf
GroovyMom (09-10-2015)
  #57
Old 08-08-2013, 03:57 PM
bernie f's Avatar
Default TSB for head rest inop
Originally Posted by JimC64
Headrest tsb as advised by Doug. Nice one
Fuse charts, convertible top, trasmission control module and tensioners as advised by Test point - many thanks
Would the TSB regarding the headrest also apply to a 2001 XK8? I have 2 that are not working and am a bit hesitant to take the seat apart without knowing what i'm getting into.
  #58
Old 08-08-2013, 04:01 PM
jimbov8's Avatar
Also check out Reverend Sam's video on U tube, shows you exactly what to do.
  #59
Old 08-08-2013, 09:14 PM
Gus's Avatar
Gus
Gus is offline
cad68m_m (03-23-2014)
  #60
Old 03-23-2014, 10:37 AM
cad68m_m's Avatar
Originally Posted by Gus
Thanks Gus this looks like another useful link.
I can't wait until I get my 10 posts in so that I can download .pdfs
Quick Reply: Jaguar XK TSB's
