Jaguar XK8 Engine Fault P1111 and P1634
Guest
Posts: n/a
Can drive my 1997 jagaur xk8 in the S button on center console to use J-Gate with no engine fault coming up not matter how long i drive it. When i hit the button to the left for cruise control and drive it for 5 minutes engine fault light comes on, the car still drives perfect with it on, the light on console you press next to the S so you can use Cruise control goes off as well, codes read P1111 and P1634 car doesnt ever drive different still drives great and has tremendous power im at a loss, turn ignition off and wait 1 minute restart car no engine fault light and cruise control comes back on and everything else is just fine,drive in J-gate no further problems until trying to use cruise control then get engine fault codes back.
Are you sure you are getting P1634?
P1111 simply means all diagnostic tests are complete - no problem with that code.
But I can't find P1634 in either the 1997 Engine codes - AJ26_97_ECM.pdf
Or in the 1997 transmission codes - 5HP24_1997.pdf
I know the previous 2 posts are ancient.
I'm only posting this if someone happens to search the P1634 code in the future.
On at least the early XK8's the P1634 code leads to this explanation:
P1634..........Throttle 'watchdog' circuit malfunction........ECM failure...... Contact dealer technical support for advice on possible ECM failure
BrentGardner
28
04-26-2024 03:08 AM
Robert1968
06-24-2017 11:16 AM
NinoGrimace
08-26-2015 05:15 AM
