Jaguar XK8 Fuel Gauge Problem - Video inside
For some reason that gas gauge drops when I get to about 7/8th tank, and goes to empty. Sometimes it will come back up as long as the fuel level is high, but normally it stays at empty until it's refilled.
15,000 miles ago the dealership replaced the fuel pump, sender, and sealing ring. Someone had mentioned to me that it might be the float binding.
I don't know much about this - does anyone know the proper way or diagnosing/troubleshooting this issue? Here is a video of it in action - thanks!
YouTube - IMG 0961 NEW
If you had that much in the tank, I don't think it would be a binding float as I said earlier. Looks more like a wire connection issue. Especially since the low fuel light is on even when it is registering a good amount of fuel. I would check the wiring connectors to the float system. Could also be a bad rheostat on the float mechanism. The fuel gauge is basically a volt meter.
I don't think it's wiring because of the consistency.. It's like clockwork -
Every time it's filled it reads full. It always works for 1/8th of a tank. Then it drops after that to empty and stays until refilled.
Reviewing the 2003 Electrical Guide:
The fuel level sensor is a variable resistor with 80 Ohm indicating full and 900 Ohm indicating empty. FC26 pins 13 and 14 are signals at the instrument cluster.Bottom right yellow connector. The full path is FK1 3&4, FT1 6&7, BT2 17&18, RH1 13& 14 , finally FC26 13&14.
An ohm meter shouild tell you if the sender is bad.
I would check your model years electrical guide before proceeding.
I think this is just another instance of the quirky electric in these cars. Something a little bit similar has happened to me once or twice after filling the tank. On initial start after complete filling, the needle is all the way at F but the amber "low fuel" warning light suddenly comes on. It stays lit for maybe 10 or 15 seconds then goes off. Again, this has only happened once or twice and I just guessed that the system took a few seconds to realize the tank was full and not empty.
Doug
Doug
Doug
Doug
My problem is something external and I think the cluster is receiving a reading which disappears under a certain level causing the gauge to drop to empty and the light to illuminate. A good way to test yours would be to toggle through the instrument cluster computer and see if it gives you an estimated mileage left while the light is on. On mine is says ERROR as soon as it drops.
BOBF: Where are these connectors located? Where should I start? I have some electrical troubleshooting expertise but when it comes to this I'm not sure if the chicken or the egg came first.
IPG, You can take a look on the below thread, some of the information may help. You can DIY repair your fuel level sender.
https://www.jaguarforums.com/forum/x...bwoofer-70631/
This only applies to the coupe, the tank must be removed on the convertible.
I think that on the 2001 and newer Coupes, the Sending Unit is located through the Assembly on the Top of the Tank.
Of course, on the Convertibles, the tank must be removed.
In fact, my Fuel Sending Unit has just began to Fail intermittently. The unit shows open circuit most of the time with a ohm meter. Substituting a 470 ohm resistor for the Sending Unit produces the expected reading on the Fuel Gage.
I have ordered a new unit from Welsh Enterprises, ($60 inc. shipping).
These Sending Units seem to be problematic. The failing unit in my car has a 10/02 Date on it and so it must have already been replaced once when my car was 2 years old.
when full works ok, medium tank fails. autonomy error. it all started after adding injectors clean the tank.
