Jerky Trans
Jerky Trans
2006 XK8 Victory - Between certain gears it almost sounds as if the car is revving between gears although the tach doesn't appear to be moving higher. The sound is almost as if you were driving a manual trans and didn't get your foot off the gas fast enough before pushing in the clutch. Otherwise, shifts and drives fine.
Any thoughts? thanks all.
