JTIS is not working Torque value HELP
Im doing the front suspension overhaul new ball joints upper and lower shock bushings roll bar bushings lower control arm bushings(the one with the ball joint) tie rod ends and front roll bar links if anyone knows any of these torque value I would greatly appreciate the help and since I will be taking the shocks out the bolts for them as well.
JTIS - 2001 XK8 Front Suspension - Torques.pdf
In case you missed Beav's recent excellent explanation about the meaning of torque settings, the higher figure is for new bolts and the lower figure for used ones.
workoutman0011 (04-09-2012)
philwarner
09-05-2015 10:05 AM
