Just Bought 2003 XK8
Just bought 2003 XK8. The Wheels and Tires were stolen when car was on the Lot. Dealer had a non running 1997 XK8 so he put the Wheels (17") on the 2003. I have been shopping for set of original 18" wheels but it's not as easy as I thought it would be. Any Member have a set to sell? Also as you can see in Pictures cars has Limited Edition Badges on both Sides. I can't find any information about a 2003 Limited Edition Model. Badges may have been added by a previous owner. Any thoughts.
Orthodixie (04-10-2017)
Congrats on the new car.
As soon as I saw the pictures, I thought, I didn't know 2003's were available with Revolvers (your 17" wheels).
Wheels should be relatively available and not too terrible. I'd find a set you like, either OEM or aftermarket (like Coventry) and choose the 18". I think the 20s are just too much for the X100, however, its it all personal preference. All X100 wheels should be easy to find and probably run $250-$400 per for a refurbished-- new will be a lot more.
I'm not aware of a 2003 LE, but I am no expert. Can you post a picture of your VIN plate (has VIN and Assembly date) and driver side sill plate. That may offer clues. Additionally, Jaguar Heritage is very helpful (there is even a ford site that can get your cars build sheet, free and instantly). Also, is the car a 5 or 6 speed (add one to the number on the left of the J Gate)?
Best!
dsd
Best!
dsd
Here's a nice set of 19" rims with just ok tires
https://orlando.craigslist.org/pts/6049799944.html
Here's a just ok set of 18" rims
https://tampa.craigslist.org/hdo/wto/6037336968.html
Yeah the Limited Edition badges are just an ebay item added for "flair" I guess. I would take them off.
NEW stick-on Emblem LIMITED EDITION chrome IP-421C | eBay
Thanks for all the replies. I think I may have found a set of wheels similar to the 18's on the Tampa Craigslist. I will remove the "Limited Edition" Badges. I looked at the Ford Build Sheet. It doesn't mention TPMS. With all the other features it would seem this would be standard. I found a Factory Radio at a Salvage Yard. I removed the Aftermarket Radio to check the wiring. The original plug is still in the car. It looks like the Speaker Wires were pulled from the plug to hook up the Aftermarket Radio. Anyone know where I might find a picture of the back of the plug to figure out where the speaker wires go in the plug.
TPMS was not offered until a few years later.
Make sure you write the serial number of the stereo before install. You may need the security code to enable it.
Also note, the factory stereo will not just slip in like the aftermarket. You will need to remove the console. There is a YouTube video on this by ReverendSam.
Best.
Best.
The relevant wiring diagram will detail pin/plug positions of various wires.
Welcome to the forum bobhof,
Got those Badges off. I don't know what kind of glue they used but I like to have a Bottle.
Wheels and Tires are on the way. Should have them here Tues or Wed.
Radio should arrive about the same time.
I had oil changed (Mobil 1). I ordered new Air Filter. I was thinking of changing Belt because I have know idea how old it is. Probably change Fuel Filter also. Anything other suggestions for maintenance?
Antifreeze is Green. Should I worry about this? Cap says it should be Orange.
