Just cleaned my throttle body. Woo hoo!!!
I was shocked at the difference this made. I've cleaned a lot worse before and got good results. It looked clean at first but as I started brushing it down with a clean soft toothbrush and carb cleaner, the dirt surfaced! Black gunk everywhere.
Just took it around the block and nearly snapped my neck back! Happy happy!
I just took the cover off. I didn't remove the actual throttle body itself. You bring up a good point though!
TB cleaning
I just cleaned mine this week end. There was some dark brown gunk on the throttle edges and on the sides of the assembly. I used throttle body cleaner that I picked up at Advanced Auto.
It is difficult to clean the unit as you have to hold the throttle up to get to the sides and outer surface of the throttle. I got mine as clean as I could, but if you look down inside where you can't reach it looks pretty dirty.
Remember don't spray the cleaner in the body intake, if you do you might get an explosion when you start the car. Spray the cleaner on one of your old tee shirts and rub, rub, rub.
I assume the breather tube that is connected to the top of the air inlet is pulling in oil fumes from the engine, which is causing most of this dirt build up. If I had a set I would remove the assembly and clean it properly. In my younger days I would have taken it off, but being an old codger, I will let the garage do it someday.
After I cleaned it, I really didn't notice any difference in idling or driving, but it looks better.
Bill N
03 XKR
Bill N
03 XKR
...I figured this out AFTER doing my cleanup job (mainly because I didn't understand the instructions in the first place) but if you turn the key to the ON position, and put something on the accelerator pedal to keep it floored (jack stand extended, and covered with a thick towel on the front seat squab is what I used) the plate will stay open for you.
The gunk at the bottom is made worse by the exhaust gases being recirculated from the EGR valve...which draws exhaust from the right bank exhaust header and directs it into the bottom of the induction elbow below the throttle body.
If you DO take off the throttle body and induction elbow, and have the opportunity to REALLY clean them out, you can get beatiful results. Here's my induction elbow after a good cleaning with degreaser. This view looks into the induction elbow from its joint with the intake manifold...that small opening at the bottom back is where the exhaust gases enter from the EGR valve. It's bright and shiny back there, too...the shadow makes it look black.
That's not a throttle body.....this is a throttle body.
Who cares if it is for a Vette??
I figured since there were two of them you would prefer the full stereo effect.
They look pretty clean already though so not sure if it will interest you 'gear heads'.
Ls1 throttle body News, Videos, Reviews and Gossip - Jalopnik
I might just have to try eBay again.
cheers,
jj
wcnesta (06-05-2012)
cheers,
jj
What throttle body? Nice *****! Save the *****!
clubairth1
29
05-10-2024 12:57 PM
xjrjag
09-27-2015 01:53 AM
