Just had a disturbing call to a jag repair shop
Just spoke to British Auto Clinic in Santa Monica California and mention I wanted to have my timing chain system checked. So he tells me why should I do that? They don't need to be checked. They don't have any problems with the tensioners.
WTF. not letting them touch my car.
Johnken (03-17-2016)
I explained to him that I bought it used and there's a chance that the tensioners are plastic and they could be damaged or ready to fail. He was not dissuaded. Ate they making noise? I said no. But, I didn't want to take a chance. Still he insists it need not be checked. If they fail it could result in catastrophic failure. Still won't change his mind. It was like he never heard of tensioner failure. I said thanks and hung up. Anyway, it was weird.
Received 2,677 Likes
There are a couple of good shops I have used on the "other side of the hill". Just Jaguar in Sherman Oaks (ask for Walt) is good but a bit pricey (still less than a dealer) and European Auto Service in (ask for Rene) is also decent and exceptionally fair pricing (he shares a building with his son who owns Mina Gallery).
Doug
Doug
That's exactly what I was thinking... it's not a cheap job, either, to be sure. If the customer insists he/she wants the work performed even after you explain you don't think it's necessary, then you do the work!
Nothing unethical about that.
I had the same experience.. Mine's a 1999... I tried to talk them into doing it as part of the deal when I bought it from them (Jag/Rover dealership) last fall, and I insisted on talking with the go-to mechanic for those cars in the shop (who knows if it was) and everyone INSISTED that if there's no problem till now, there never will be...
I asked to at least look at them but they wouldn't because they had already done their "standard inspection" (which I have the papers for and is thorough, but... c'mon, you know?)
Yes, they're @$$holes.
O_o
It's got 68,000KM on it............ went into winter storage where it is now only 3 weeks after I got it.
Would you guys suggest I swap them for the metal tensioners, regardless of how they appear? (once I can get at it)
O_o
Cyber3d...I faced the same denial of this issue as well, from the PO, from the local Jag dealer and from online "experts". Then I got the wait till 100k argument...I researched the issue extensively getting the best 1st hand experience from this and other forums. My car only had 40k miles on it. I followed the experience...had the tensioners done by an indie and sure enough both tensioners and one guide were cracked. Not doing the service could be up to a $10k mistake.
I ordered metal tensioners from SNG Barratt in the USA. Cost $US117 (with my jagforum discount) + shipping to Australia.
My indie installed them for $AUD400/$US300.
I'm Happy!!!
I couldn't sleep at night due to the thought of secondary tensioner failure. I've got a new to me 2001 XKR. My car had 2nd generation plastic tensioners and they were just beginning to crack at 100000km/62000miles.
I'm Happy!!!
I'm Happy!!!
So, $300USD right now should be roughly... $118,000,000 CAD.
hhahahaha. ****.
If you are just going to do the secondary (upper) tensioners, its quite a straightforward DIY job if you do it via the ziptie method as documented on this forum.
On my March 2001 XKR with 40,000 miles on it, the secondary tensioners looked almost like new. From what I could see of the chain guides, they also looked perfect, so I was quite happy just to change the secondary tensioners. Parts costs were in the region of £110 plus delivery to Spain, which seemed like cheap insurance to me.
Higher mileage cars, or ones that have been used for lots of short journeys may well have tensioners in worse condition than mine, as most of the strain on them seems to be when cold starting. Its easy enough to check the condition though by removing the right hand side cam cover and having a look.
Well Cyber3d I've heard the same thing from a dealer in Maryland (where I bought my car) and a local indy shop here. The dealer's head mechanic said: "I've been working on Jags for 35 years and never had a cam chain tensioner fail. It's an internet myth"
I replaced mine, at 50k miles, one of them crumbled in my hand as I removed it. Myth? I think not.
and emaycheb, the dollars up today, won't be more than a million.
