Just hit the 101,000 milestone! So, what's next?
101,000 miles on the odometer! Well, the car has not been in the shop for four months now, and seems to be running great, albeit a rattle here and there only a true perfectionist will notice.
Over the last three years, i've had alot of work done on her, some DIY
My left HID flickered (went out for a few seconds) twice yesterday. That bugs me! And, I could not recreate it when I tried, thought it was the left/right sudden turns.
Anyone care to guess what might be my next problem or repair that I will eventually entertain?
- suspension - upper mounts, and all bushings
- CCV and vent tube replaced
- headreasts repaired (twice...my fault)
- brakes and rotors
- hydraulic hoses and 'rams'
- lower steering column (new tilt/reach motors!)
- transmission service
- re-aligned my driver window
Welcome to the 100,000+ mi club. You apparently been christened by the green monster, entertained by replacement of the upper mounts and played with the windows. You are now officially a Jaguar xk8 owner and have the right to say what you want.
Any questions about you meeting the criteria just ask me!
You asked what should you expect in the future? The answer is, there is no answer!
Is the magical substance SEA FOAM !
I think Cheech and Chong called it MAGIC DUST.
http://www.youtube.com/watch?v=QWGBeADI_8E
Merry Christmas!
Merry Christmas!
I'm sorry I just couldn't help myself. My jag doesn't run at all so I can talk all the smack I want!
As for your HID, sounds very much like a loose, or frayed wire. Check the connections and follow the wires, see if you find a zip tie rubbing through the sheath or something of that nature. -Shaun
I saw a suspension kit being offered for %70 off retail price from Welsh Enterprises and got really excited only to find out its for 1999 -2000 models. Mine is 2003.
The kit includes:
- LHF & RHF OEM Upper wishbones
- 2 Front roll bar insulators
- 2 Front sway bar links
- 2 Lower ball joints
The kit includes:
