Kenne Belled XKR's performance
Mark
Not X100, but a KB AJ26 4.0 XJR has done 0-191km/h (118.82mph ) in 11.924s. That's the official 1/4mile result.
Um yeah it will,
![Icon Lurk5](https://www.jaguarforums.com/forum/images/smilies/icon_lurk5.gif)
To some it up, that thing is pure wicked evil and devil eggs, and can provide more boost than any engine can ever want.
Um yeah it will,
,that blower will produce enough torque and power to make the weight of his car almost useless. Ive seen trucks at the tracks that weigh over 5000+ lbs run 11's and tens with that blower alone.
....and the SC is just part of the combination.
What do you mean saying optimized intake? TB bored out, new inatke elbow between TB and blower or intake pipe from air filter to TB?
Why not test it on a dyno? Or a 1/4 mile strip?
Forum's 1/4mile standings: https://www.jaguarforums.com/forum/m...andings-84783/
JCNA Forums - Jaguar Clubs of North America
here is a 2000 xkr with a 4.0, 600HP with the 2.6
Now, on the street 0-60 times are what count.
https://www.jaguarforums.com/forum/x...-0-60-a-64471/
as you can see,you can do 0-60 in under 5 seconds flat,and run a low 13's stock with the xkr in stock trim.
Well, my pulley is 2.68''. That means my KB 2.2 will flow comparable air volume than 2.6 with 3.25'' pulley. Maybe I'm to optymistic but I expect similar results as with 2.6L unit.
SteveM uses stock MAF and TB and his results are great. His XJR really smokes XKR-S and XFR.
My car is not ready yet but it will be back on road in 3-4 months. I can't wait to check it on dyno.
You said your pulley was 3.25 in your 1st post.
I have only experience with the bigbore units, and the 2.6LH which I am using is also a higher compression unit that consumes less power. This leaves more power to the wheels, and also means that you would have to turn it already faster to get closer.
As I haven’t seen how you have done your intake elbow, I can only guess, at least I would guess with the 2.68 pulley you want to use, you should be north of the 400 rwhp, maybe 430?
Have you done a baseline dyno with your car?
That's avos car before change from 4.0 to 4.2. I remember the power with 4.0 was about 575bhp.
